Results 1 to 10 of 17
Thread: Who Let The Dogs Out..............
    15,774
    ......Bench Dogs, that is.........
    I have a nice large Record woodworking vice on the one corner of my work table/bench. When I have to hold something flat on the bench, say to hand plane it, I will often screw a block to the top of the table, which works, but makes a lot of holes in my table top.....
    This is how I used to do it, block screwed to the bench top
    So this is what I started with....
    I have this nice thick chunk of wood, it is White Oak, and was from an old table that I got from the curbside. Hard, flat dry, should work well.
    I cut a shoulder on the insert piece
    I used some plywood scraps to make a template of sorts to make the cut.
    Here I did a shallow cut just to check the fit....
    Here I've cut the first cut, the part where the shoulder will fit
    Here I am setting up to cut the deeper cut, for the insert.
    There it is, it fits!
    OK, it is done, I did NOT glue it in place, I just screwed it down, in case I need to replace it at some point.
    Now I need to make some bench dogs
    Zushi, Japan
    739
    Looks nice and clean and mighty functional Stu. Seems I'm always upgrading my bench one way or another. The latest for me is I finally got round to attaching the new quick release Jorgenson vise I bought about six months back. Of course I had to drill more holes in the benchtop to do it.
    15,774
    Thanks Alex.
    Cutting a hole in the top of my worktable makes it look better, but you nice bench, man, that would be hard to do!
    Looks like a Well Used Bench, and a good modification and a good idea. Some of us common folks who have battle scarred work benches can use that approach.
    I especially like that you pictured your planes correctly placed on their sides while laying idle. (This will start a Hurah from the knuckle draggers who insist it don't matter. )
    15,774
    Thanks Bill!
    My Grandfather would smack us upside the head if he ever saw us put a plane down NOT on it's side, so I guess I that is where I get if from, I don't really care which way is "Right", I just do it the way I was taught.
    Decatur, Illinois
    177
    stuart, don't know if you're going to build rectangular bench dogs or round...but if rectangular see this video...
    http://www.taunton.com/finewoodworki....aspx?id=26990
    i followed it for my new workbench dogs and they look like this...
    99% of lawyers give the rest a bad name...Steven Wright.
    15,774
    HI Clark, thanks for the info, but I'm going to start with square stock and then turn the shaft, leaving the head square.
    Great idea Stu. I need to do something like that on my bench as well - now ya got me to thinking - always dangerous.
    Wes
    Steve Clardy Guest
    Catalunya
    4,631
    Hi Stu.
    Looks good! Now you can use the bucks that you save from screws to fill in the rest of the holes
    You say you need to make some bench dogs...
    I'd say you need only one, don't you So make sure it is THE ULTIMATE BENCH DOG
    Sorry Stu, today I got up with this "tongue in cheek" frame of mind, it's friday and I'm tired of a hectic week, thanks God we still have woodworking to keep us sane.
    Best regards,
    Toni
  1. Dogs
    Last Post: 03-09-2014, 03:23 AM
  2. dogs and pot in Colorado
    Last Post: 02-26-2014, 10:34 PM
  3. Corn Dogs
    Last Post: 07-06-2010, 03:54 AM
  4. Bullet Dogs
    Last Post: 10-12-2008, 04:23 AM
  5. Corn dogs!!!
    Last Post: 10-06-2008, 02:50 AM
