Results 1 to 10 of 11
Thread: Vacuum Rig
    15,815
    Vacuum Rig
    OK, I have a decent vacuum pump......
    ........and now I want to make a "Vacuum Rig", I've had a good look at www.joewoodworker.com and I think his article on the EVS Set Up looks like the way to go, at least the concept, if not the actual system.
    Some of the things he talks about in his EVS I'll get from him, as I have no idea where to get them here in Japan.
    I was wondering if anyone else has built this type of system and can offer some advice?
    I want to use it for a vacuum chuck on the lathe, and a vacuum bag for veneer.
    BTW, the 20mm ID hose, I think they call it "Braided Tubing"
    I got for the vacuum pump, well, if I stick one end on the pump, and block the other end, the pump sucks it flat as a pancake in about 2 seconds......Maybe this pump is a bit too big???
    stu, for your bag go ahead and pop for polyurethane over vinyl you`ll be glad you did.. if you intend on doing wierd stuff go 20 mil for flat work 30 mil..
    15,815
    Thanks Tod, the "Weird Stuff" I assume you mean wavy, curvy etc, I imagine you are saying 20 mil (thinner) as it will conform better to the "Weird Stuff".......??
    30 Mil for flat stuff, OK, I get that
    I'll most likely order the bags from Joe woodworker, as I'll be ordering some other stuff from him, and shipping is always the killer, so I'll do my "Buy the best I can" thing. No sense in buying cheap, and paying for shipping, IMHO.
    i`ve never delt with "joe".....i get my bags from qualityvak....nice guys there too if you`re interested?
    15,815
    Must be these guys.........
    http://www.qualityvak.com
    thanks for the info Tod, always good to have another source!
    yup, ed`s the owner and neil is his son.....knowledgable and fair.
    SE Minnesota
    2,550
    How much vacuum are you drawing? How much do you need to draw?
    15,815
    Quote Originally Posted by Dave Richards View Post
    A LOT Dave, this pump really sucks, it is not a small pump, but a large commercial one. I was told recently that they retail new, here in Japan, for about $3000
    SE Minnesota
    2,550
    Have you measured the drop?
    Thomasville, GA
    6,125
    ... BTW, the 20mm ID hose, I think they call it "Braided Tubing"
    Stuart,
    That looks like the same type of tubing I use, but mine is 1/4"ID whereas yours is more than 3/4"ID. Is there a reason you went with such a large ID? I've never seen a system, even in commercial shops, where anything larger than 1/4"ID is used. The larger ID tubing will be much more likely to collapse.
    Bill Arnold
  1. How much vacuum do I need
    By Dave Gallaher in forum General Woodturning Q&A
    Last Post: 09-27-2011, 04:37 PM
  2. Vacuum Pump
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 03-03-2010, 02:16 AM
  3. Vacuum Pump
    Last Post: 02-27-2010, 04:25 PM
  4. Vacuum Chucking
    Last Post: 12-29-2009, 02:23 PM
  5. Vacuum Rig Ver. 2.0
    Last Post: 03-28-2008, 12:03 PM
