Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 51
Thread: Doug's shop tour
    La Habra Hts. CA
    399
    Doug's shop tour
    Well I finally got around to taking some pictures of the shop in a somewhat organized manner. The shop is on the same property as my concrete business. Up until a few months ago it was leased out to another party. Since they moved out I did some major remodeling and added on a little bit. The shop is roughly 23x80. Here's a few exterior shots.Click image for larger version.
Name:	Shop Tour 002.jpg
Name:	Shop Tour 001.jpg
    Now onto the equipment. Here's the Ritter line boring machine set up for line boring.Click image for larger version.
Name:	Shop Tour 003.jpg
    This pictures shows a rack I'm going to primarily use for sheet good storage. Right now it's still a bit cluttered.Click image for larger version.
Name:	Shop Tour 004.jpg
    The next two pictures show the 20" martin jointer, the second shows how long the bed is. It also has a hookup for a power feeder but I doubt I will use it.Click image for larger version.
Name:	Shop Tour 005.jpg
ID:	1142Click image for larger version.
Name:	Shop Tour 006.jpg
    The next two are of the 24" planer. It's set up next to the jointer in a space saving configuration.Click image for larger version.
Name:	Shop Tour 007.jpg
ID:	1144Click image for larger version.
Name:	Shop Tour 008.jpg
    The last picture for this post shows the edgebander. It's a Brandt, does up to 3 mm, laminates, all tapes and solid wood up to 3mm if you mill it yourself.Click image for larger version.
Name:	Shop Tour 009.jpg
    I'm going to have to make two more posts to get the rest of the pictures in. I'm new to posting pictures and text so I hope it came out all right.
    Regards Doug
    looking good so far doug, keep em comming.
    La Habra Hts. CA
    399
    Here's the Martin Slider, it's the T 60 with a 3.3 meter slide and manually adjustable scoring.
    Attachment 1147
    This is a close uo of the control panel. It shows blade height, angle and distance to rip fence.
    Attachment 1148
    This shows a panel support bar that fits anywhere along the slider. It can be used by itself to help support large panel and it can also be used with the parallel fence attachment.
    Attachment 1149
    Here's one moe shot from a different view.
Name:	Shop Tour 013.jpg
    These two show the Castle pocket machine and also a refrigerated dryer for the compressed air system. I ran a 1" copper line about 80 feet from my other shop to feed the woodshop.
Name:	Shop Tour 014.jpg
Name:	Shop Tour 015.jpg
    This pic shows the DC. It's a dantherm 7.5 hp The ducting starts out at 11" dia. and drops down to 4" at the furthest machine.
Name:	Shop Tour 016.jpg
Name:	Shop Tour 017.jpg
    I found this saw on the internet. It was purchased brand new in 2000 by a gentleman that was going to start a furniture business. It never happened and the saw never even had a blade on it and was still on the original shipping pallet when I got it.
    It's an 18" Northfield with 7.5 motor. I think it was the only year they used this color, it's kind of a light yellow. The following year they went back to the green. It is a beast and weighs in at a mere 2000 pounds. Just a little less the the slider. I got it primarly for a rip saw for hardwoods and equiped it with a power feed. It was such a good deal I couldn't pass it up. I negotiated with the guy and I paid for shipping.
Name:	Shop Tour 018.jpg
Name:	Shop Tour 019.jpg
    I think one more post will show everything else.
    Regards Doug
    La Habra Hts. CA
    399
    Ok here's the final set of pics.
    Wall mounted lumber rack, loaded with 4/4 maple
Name:	Shop Tour 020.jpg
    This unisaw is going to be used mostly for dado cuts, especially for the grooves in cabinets for the 1/4 backs. I'm going set up a power feed and have a 1/4+ dado blade made up and run the parts backwards (with the feeder of course) Kind of the same principle of a scoring blade. This will extend the life of the blade and keep the malemine from chipping.
Name:	Shop Tour 021.jpg
    This shows the chop saw station and general bench for hand tools etc.
Name:	Shop Tour 022.jpg
    This is a single head butfering 37" wide belt, it pulls 50 amps! Also I made a storage rack for the belts out of pvc closet rings and 4" abs pipe.
Name:	Shop Tour 023.jpg
    These two tools are great to have around-parts cart and panel cart.
Name:	Shop Tour 025.jpg
Name:	Shop Tour 026.jpg
    This spot is reserved for the shaper. It's already got the power(disconnect) air supply and two 5" ducts for DC. It should be here by xmas. I'll wait and give more info on it later when I can show pictures of it.
Name:	Shop Tour 027.jpg
    The last three are overall shop pics.
Name:	Shop Tour 028.jpg
Name:	Shop Tour 029.jpg
Name:	Shop Tour 030.jpg
    Southern Georgia
    1,396
    Wow Doug,
    Once I get over the immense tool-envy, I'll post a few comments and questions. In the mean time, I'll be slobbering on my keyboard looking at the pictures.
    Thanks for posting...I think...
    - Marty -
    Fivebraids, Inc.
    When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there’s no end to what you can’t do…
    La Habra Hts. CA
    399
    Quote Originally Posted by Marty Walsh View Post
    Wow Doug,
    - Marty -
    Thanks for the kind words Marty. I'm sure your going to have some nice equipment in your shop. You have to!! It wouldn't be right after you put all that work into your beautiful shop.
    Btw youv'e never really elaborated on what toys are going in there except your new slider. How about a few hints.
    Doug
    2,784
    Marty, I now need a new keyboard. Do they make water (slobber) proof models? Wow is right, Doug. Those are some serious machines! Nice setup! And what part of the concrete business are you in? I grew up in a redi-mix concrete business owned by my grandparents. My dad was the plant foreman. Lots of good memories, but it was a tough business.
    (sigh) Now I have to force myself to go out to my shop in the morning and work on my cyclone chip barrel..... Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    La Habra Hts. CA
    399
    Quote Originally Posted by Jim O'Dell View Post
    Thanks Jim,
    I specialize in place and finish. Mostly industrial floor slabs, tilt-up panels, structual and metal decks. It's all labor and a ton of equipment. We have a about 10 flatbeds, 20 ride on trowels and about 40 walk behaind trowels. Plus a bunch of other misc. equipment and small machine shop and a fulltime mechanic.
    Yes it's a very tough and stresfull business. The last floor we completed started at 1 am in the morning and we poured about 55,000 sq ft. a day which is approx. 1,250 yards per day(125 redimix trucks) for 12 days straight.
    Out here in So. Cal the big supplier is Robertsons redimix.
    Doug
    Georgia
    114
    Wow is right!
    Doug,
    A really impressive collection of tools you have ...
    A very well stocked shop for sure!!
    Denise
    Southern Georgia
    1,396
    Quote Originally Posted by Doug Sinjem View Post
    Doug
    Doug,
    Rest assured, I will NOT have the caliber of equipment you've shown us here!! Perhaps if I already had a shop, and didn't have to spend all my time and money building one, I might...just might...have the luxury of such first class gear! No, on second thought, you have more money tied up in equipment than I do in my shop. Never mind...
    As for hints as to what's going in my shop....
    NOPE!
    It'll be clear enough when I get the floor done and start wheeling the stuff in. But as I said, it'll be a kids starter-set of what you have.
    Oh, and I almost forgot, I wanted to compliment you on having some sawdust around. Nothing worse than a sparkling clean shop...
    Still drooling...
    - Marty -
    Fivebraids, Inc.
  1. Shop - Organizing the clamps, finally! + Shop Tour
    By Rob Damon in forum Shop Tours
    Last Post: 02-09-2011, 04:16 AM
  2. My Shop Tour
    By Ralph Jones in forum Shop Tours
    Last Post: 04-15-2008, 04:25 PM
  3. Shop tour
    By Garry Smith in forum Shop Tours
    Last Post: 02-28-2007, 04:05 PM
  4. Shop Tour
    By Jay Brewer in forum Shop Tours
    Last Post: 02-04-2007, 08:45 PM
  5. The new before tour of my shop
    By Julio Navarro in forum Shop Tours
    Last Post: 01-24-2007, 04:02 AM
