Results 1 to 5 of 5
Thread: Drawer Spacing Help!
    Matt Dunlap Guest
    The Heart of Dixie
    4,268
    Matt, I would just make me a sketch, doesn't have to be to scale. Just add some dimensions to to it and you should be able to work it our really easy. Take what you said, put it on paper and it should be obvious.
    I have a job this morning or I would sketch it out and show you what I am thinking.
    Custom built boats and Kits
    9,109
    I did this quick as I'm heading to work but sorta . . . pick the height from the carcase bed to the underside of your drawer body, lets say 3/8". First glides go here, add face height plus gap and move up. My 1/8ths are rounded in the diagram, didn't have time to format the numbers.
    Houston, Texas
    2,323
    Quote Originally Posted by Matt Dunlap View Post
    I crunched numbers for 2 hours last night and still haven't figured out how to space my drawers for a project I have. Is there a formula for easily figuring out where to put the drawer slides?
    I've got 4 drawers that are 5 1/2" high and will put undermount slides on them. The drawer faces are 7" high each. The cabinet interior is 28 5/8" high and I plan on having 1/8" between each drawer face and also 1/8" space at the bottom and top. The drawer faces will be centered on the drawers.
    HELP!!!!!!
    Matt, this is a classic example of "It is time to make a story pole".
    Get a straight stick, longer than the height of your cabinet, about 1 1/2" wide. I use a stick rule but a tape measure will work. you need a pencil and I use a combination square and i usually need an erasure or sandpaper to eliminate incorrect marks. Mark the finished height of your drawer holding box. mark the height of your base and whatever molding if any. Building from either the bottom up or the top down or the center out with your marks. Determine where your 28 3/8 (4- 7" fronts and 3-1/8" spaces. ) drawer fronts with the spaces will fit. Mark them in full scale on your story pole ( just vertical). This lets you know the exact size space behind the fronts for drawer and drawer guides and allow you to determine exact, to scale positioning. I need hurry off but will explain more with a drawing later if you like.
    Good luck.
    Please join me. Register now.
    Shaz
    Here is how
    9,109
    Lesson learned: When it doesn't work the way you think it should, step back and look for what you missed instead of trying to make it work.
    Amen Brother. I solve more problems by walking away and going to do something else than I ever do staring and stressing.
  1. Inset drawer spacing
    Last Post: 01-02-2012, 02:20 PM
  2. Stair construction and tread spacing
    By Brian Shepley in forum General Woodworking Q&A
    Last Post: 02-28-2010, 01:20 PM
  3. my very first drawer!
    By Mark Kosmowski in forum Flatwork Project Showcase
    Last Post: 05-19-2008, 10:04 PM
  4. Dog Hole Spacing
    By Mike Gabbay in forum Neander Woodworking Q&A
    Last Post: 11-28-2007, 07:38 PM
  5. Attaching drawer fronts to the drawer.
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 02-27-2007, 04:11 AM
