Results 1 to 10 of 24
Thread: Rebirth of a lathe, needs a name?
    Jul 2007
    DSM, IA
    5,719
    I told you all some time ago that I would be redoing my lathe. Well most is done. New Base and new paint. All that is left to be done is replacement of the bearings (next weekend) and adding a ballast box for sand to make it more stable. I will add pics below, but here is how it looked when I started.
    Jul 2007
    DSM, IA
    5,719
    new base
    Sorry folks, can't get image attachment windo to open. Will try again later.
    Jeff
    Jul 2007
    DSM, IA
    5,719
    Here are some pics of the new base made from pressure treated 4X4 and 2X4 I had laying around. Added a shelf to make it stronger that will be bottom of the box to add sand to make it more stable.
    Jul 2007
    DSM, IA
    5,719
    Sanded and ground down and ready for primer....and then primed. Looking much better already. Last pic is the tool rests, banjo, tailstock and the 1X8 tpi bolt that goes through the tailstock that is bored for 1/2 bolts. Has a "nonlive" center and a jacubs chuch that can go in it.
    Attached Thumbnails Attached Thumbnails preprimer.jpg   primer.jpg   primedaccess.jpg
    Jul 2007
    DSM, IA
    5,719
    The finished paint job. I haven't painted the pillow blocks that hold the bearings. I want to wait until I have the old bearing out to get a better finish. I will post more detailed pics I have when I have more time. thanks for looking.
    Forgot to mention I went with Massey Furgeson gray for the paint. Jeff Horton reccomended the paint and if you ask me it looks like it will be hard as nails. thanks for the tip Jeff
    Attached Thumbnails Attached Thumbnails finishbase.jpg   finishlathe.jpg   finished.jpg
    lathe`s lookin` good jeff!
    no suggestion for a name..
    Red Deer, Alberta, Canada
    618
    Looks great, Jeff!
    If I had done as much work on that as you obviously have I'd probably stencil TGIF across the front: for Thank God It's Finished.
    Jul 2007
    DSM, IA
    5,719
    I forgot to mention my idea for a name. The original base that was white in color is from a Maytag Model B-10 clothing press/iron...and the motor and speed control are from a clothes washing machine, but don't know what brand. I thought of just calling it the B-10 or The Maytag, but thought maybe someone might come up with something else
    15,811
    Looking good, but why is the tail stock end hanging way off in space like that?
    I DO name some of my machines, ones that have my sweat and blood in them, not the store bought ones, usually.
    I'd just wait, no hurry to name it, if it is going to be named, a name will come, you never know from where.
    Jul 2007
    DSM, IA
    5,719
    Stu, the tailstock end has looked like that since it was made. The longest thing I've ever turned was a bb bat for my BIL...and the tailstock didn't get out to far past the end of the stand. I need to take some measurements to see what the total length of the bed is between spindles??
    I think you're right about the name....it will come to me with time.
  1. Replies: 14
    Last Post: 01-14-2014, 03:57 PM
  2. Midi Lathe/Stand setup... aka help me set up lathe land in my shop.
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2012, 06:41 PM
  3. Grizzly lathe G0698 discontinued vs New Grizzly lathe G0733 Both 18"x 47"
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 12-29-2011, 03:23 AM
  4. The Rebirth of a Hoosier Cabinet, DONE, final pic
    By larry merlau in forum Flatwork Project Showcase
    Last Post: 03-07-2010, 03:13 PM
  5. The Birth & ReBirth of an Air Cleaner/Filter
    By Sean Wright in forum Jigs and Fixtures
    Last Post: 06-07-2007, 12:49 PM
