Results 1 to 10 of 24
Thread: NEW Lathe
    Contoocook, NH
    129
    NEW Lathe
    Hi fellow turners.
    I'm in the process of choosing a new lathe, I've found a Jet mini vs with extension and stand for 495 or the Grizzly G0462 for 484 delivered.
    Which one would be the better of the 2 ? Looking for help will be ordering the end of this week.
    Thanks for the help.
    PS I have to keep the cost around $500. I'm asking about the best in my pricerange.
    Richard "Butch" Leshner
    Indiana
    224
    What's your goals in turning?
    Just remember, you can turn small things on a big lathe, but you cannot turn big things on a small lathe.
    For $88 more you could get the Jet 1236, or for $99 more you could get the Delta 46-715 at Amazon.com. I'm sure shopping around may even give you better prices than that.
    Keep in mind though, the Jet mini is a proven lathe. You can't go wrong there.
    Contoocook, NH
    129
    I plan on turning tool handels, segmented bowels, pens.
    Do you think the delta 46-715 is better than the grizzly?
    I've read alot of bad reviews on that one.
    the delta was my first choice till I saw the bad reviews.
    Someone on the creek said they could get 46-715r for 299.
    If I could find that deal I'd go for it.
    Thanks again for suggestions.
    Indiana
    224
    If the Grizzly is Variable speed,, that would be my choice.
    Contoocook, NH
    129
    It has variable speed but uses a reeves drive setup.
    Specifications and Features:
    Motor: 2 HP, 110V, single-phase
    Swing over bed: 16"
    Distance between centers: 43"
    Heavy-duty, precision ground cast iron bed and cast iron legs ensures stability and minimal vibration
    1" x 8 TPI RH headstock spindle
    Spindle tachometer with digital read out
    MT #2 spindle & tailstock tapers
    Spindle bore: 3/8"
    Outboard turning is easy with standard tool rest extension
    10 speeds: 600 - 2400 RPM
    Quick lock/release levers for tailstock and headstock
    0 deg., 60 deg., 90 deg., 120 deg., and 180 deg. headstock rotation
    Overall dimension: 76 1/2"L x 19"W x 48 3/4"H
    Approximate shipping weight: 304 lbs.
    The only thing I don't like about the Grizz is the lowest speed seems a bit high to me, when I turn big stuff and it is out of round I like to turn a bit slower then 600 RPM. I do like the 2 HP and the 16" swing. Some don't like the reeves drive, personaly I see nothing wrong with it.
    Richard............I have a Jet VS Mini.........lowest speed is 500 rpm IIRC. Even when turning a 9" rough blank 500 rpm is too fast for an out of balanced blank. Good luck with your decision.
    15,811
    Hi Richard!
    If you want to turn bowls, and they blank is out of round, 600 is WAY too fast IMHO, especially for a begining turner.
    Do you have a bandsaw?
    I ask becaue one thing you CAN do it to make sure that the blanks are as round as possible, and flat too, with a bandsaw you can go a long ways towards this.
    May I ask why the rush?
    You really don't want to get stuck with a lathe you don't like and only have to sell it at a loss later to get the lathe you should have bought the first time.
    Look around some more, I hear good things about the Rikon Maxi lathe.....?
    Houston, TX
    363
    Richard, the $299 Delta is from Redmond tool (goggle it) and is a repaired unit. It and the Griz both have Reeves drives, the Jet I had (1442) used reeves and started at 425 rpm IIRC ant that was awfully fast if the blank was not well balanced.
    Indiana
    224
    Quote Originally Posted by Richard Leshner View Post
    I read the reviews also, the way I understood it was there were two versions of this lathe and the earlier one is the one with the problems.
    With that said, I still like the Grizzly of the three brands but the Jet is a good one. just looks like more bang for the buck.
    At a glance, I'd go
    1.Grizzly/ Jet
    2. Jet/ Grizzly
    3. Delta
    4. HF
    5. Jet mini/ Rikon mini.
    Again, this is only my unprofessional opinion.
  1. Replies: 14
    Last Post: 01-14-2014, 03:57 PM
  2. Midi Lathe/Stand setup... aka help me set up lathe land in my shop.
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2012, 06:41 PM
  3. Grizzly lathe G0698 discontinued vs New Grizzly lathe G0733 Both 18"x 47"
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 12-29-2011, 03:23 AM
  4. first on new lathe
    By Stephen Bellinger in forum Turning Tool Questions and Show & Tell
    Last Post: 02-21-2010, 03:49 PM
  5. Box on lathe
    By Sandra Meyer in forum General Woodworking Q&A
    Last Post: 07-16-2009, 01:16 PM
