Results 1 to 10 of 20
Thread: Difference between single sided and double side sawblade?
    Punta Gorda, Florida
    902
    I was going to get a Freud laminate and melamine blade. I see that Freud has two: 1. LU98R010 Single Sided Laminate and Melamine blade 2. LU97M010 Double sided Laminate and Melamine blade.
    The both appear to do the same job. What is the difference?
    Charlotte, NC
    1,487
    Looking at the Freud site the difference is in the rake of the teeth. Single sided blades have a positive rake which will provide a more aggressive cut. The double sided blades have a negative rake.
    LU98
    LU97
    902
    Thanks Ed,
    Which would be the best choice for cutting 3/4" melamine and/or 3/4" solid stock that is laminated.
    Charlotte, NC
    1,487
    There is a Freud rep that posts on the NCWoodworker forum. I will forward him your questions. Do you have an email address I can forward to him? Send me a PM and I will pass it on.
    902
    Here it comes Ed. Thanks!!!!
    Charlotte, NC
    1,487
    Email sent. If one of us doesn't hear from him soon, I would recommend seeing if there is a Freud rep in your area. Based on the ones I've met, they're good people and are quite willing to help out. I'm hoping Charles will join in over here to help out!
    Rochester
    846
    Quote Originally Posted by Allen Bookout View Post
    Thanks Ed,
    Hi Allen - I've been called lots of things over the years, but "Charles" has never been one of them. I don't know if he checks in over here, so I'll offer what I know of these blades.
    I haven't used either of these, but AFAIK the LU97 should leave a slightly cleaner cut with lower tearout due to the neg hook. It should also hold up a tad better because of the neg hook too. The triple chip grind should hold up really well on both though. The LU98 will feed a bit faster though, so go with what's most important to you...depending on your saw and how much you need to cut.
    If you need the ultimate in clean cut, you might consider the LU80R010 with Hi-ATB grind if you don't have alot of it to cut. This is simply the cleanest cutting blade I've used to date, but those pointy tips will abrade a bit faster than the TCG teeth.
    Got Wood?
    Odessa, Tx
    1,813
    I'm glad you asked this question, Allen. I have thought, (but not sure), that the LU98 (single side blade) is meant for cutting Melamine, MDF, Laminated Plywood or Laminated MDF that is laminated on only one side, and though slower because of the negative Hook angle, the two sided LU97 was made to cut melamine and or other material with laminate on both sides, or give a "finish" cut on BOTH sides of whatever material is being cut. I have no idea if my thinking is correct or not. I hope Charles, (or someone who knows) will reply.
    Lake City, Florida
    498
    Hey Allen, When cutting Laminated Plywood or Laminated MDF I have always found it best to rough cut to 1/8 - 1/4 inch big then finish with a 3/4" carbide flush cut trim bit in the router. Cutting from the edge rather than the top gives an edge smooth as a baby's butt with no chipping of the laminate. Use a straight edge clamped to the workpiece to guide the router or the bearing on the bit.
    Granted, it's a little more time consuming but I don't use laminates very often.
    Tony.
    Tony, BCE '75
    902
    Scott and Norman, You guys are right on it appears. Since I do not have a ton of it to cut it looks like that the LU80R010 is the best for me for the best cut on both sides. The LU97M010 best second option. The LU98R010 last longer but not the quality cut on both sides as the other two.
    Hi Tony, How are you doing? Being a perfectionist I would expect that of you.
  1. Better than double sided tape
    By Jay Caughron in forum Jigs and Fixtures
    Last Post: 04-07-2016, 05:30 PM
  2. Double Sided Coin Project - XYZ Zeroing
    By Brent Dowell in forum Programming, Troubleshooting, and Q&A
    Last Post: 01-18-2016, 02:29 AM
  3. Double Sided Tape
    Last Post: 02-11-2014, 03:52 AM
  4. Double sided tape?
    Last Post: 09-06-2011, 08:47 PM
  5. Double Sided Tape
    By Dan Mooney in forum Jigs and Fixtures
    Last Post: 02-01-2009, 08:34 AM
