Results 1 to 10 of 11
Thread: First Hollow Form
    Melbourne, FL
    474
    First Hollow Form
    Well here it is - Finished up to 36 grit just prior to applying the finish.
    This looks to me like it will be a good seller in the local art galleries.
    What do you think?
    Anybody care to guess what it may be?
    Stayed tuned - more info in the next few weeks.
    30,230
    Finished to 36 grit? Man Pete, you're sparing no expense, huh?
    I'm curious to see what it becomes.
    Fort Worth, Texas
    241
    You're turning a crankshaft wheel? That's cool!!
    I may be lost but I'm making good time!
    Three Seasons Woodturnings
    Jul 2007
    DSM, IA
    5,719
    I like the burnt line just below the rim
    810
    Hmmmm, a pulley for a drive belt?
    Melbourne, FL
    474
    You are correct
    John - You are on the right track.
    Seems the Mini is a little mis powered and can use a little help.
    Neal - You also have the right idea.
    I have heard they make sandpaper in finer grits than 36. I may have to look into getting some of that stuff. I may even move up to 80 if I can find it!
    Stayed tuned or turned.
    Fort Worth, Texas
    241
    Psst... I know a guy who knows a guy who can even get you 100 grit. Just don't tell anybody or before you know it everyone will be using it.
    Charlotte, NC
    1,487
    Looks, um...Great!
    Melbourne, FL
    474
    More Power for the JET
    I have been wanting more power for the Jet Lathe. Got a good deal on this old iron 3 phase 12 hp motor so I thought adding it to the Jet would help turning hard woods.
    Note the thin piece of cherry on the lathe. This was turned without the new extra power. It seemed to have one section that was very hard. So hard that it just would not cut.
    I was going to nail this thin bottom onto the hollow form to make a fancy wood wine glass. I guess I can still use it as a bottom and just say it has a built in shelf to hold your cheese. What a great idea - wine and cheese all in one hand!
    Stayed tuned more mods on the way.
    Melbourne, FL
    474
    Jet - Coil Winder
    I had a few of these to wind for a local science project so I rigged up a JET Mini Coil Winder.
    Singer Sewing Machine motor with foot speed control and a cam operated counter.
    The coils are a little rough because one wire actually loops back under the windings.
    Works real smooth and easy to add or remove from the lathe.
    I guess I will just have to learn to work with the underpowered lathe once I remove the aux motor!
  1. first hollow form
    By Clark O'Neill in forum Lathe Project Showcase
    Last Post: 04-14-2008, 02:08 AM
  2. How long does it take to hollow out a small hollow form?
    By Mike Hirsch in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 07:47 PM
  3. Box? Not exactly. Hollow Form? Well, no....
    By Kerry Burton in forum Lathe Project Showcase
    Last Post: 05-12-2007, 10:28 AM
  4. The Next Hollow Form!!
    Last Post: 05-01-2007, 02:34 AM
  5. Hollow Form
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 04-30-2007, 10:34 PM
