Results 1 to 6 of 6
Thread: What finished is crib safe?
    La Habra Hts. CA
    399
    Building a crib out of walnut, so no stain needed. What kind of clear finish would be safe for the baby? Would watco oil work? Any suggestions would be appreciated.
    Doug
    MX
    146
    Shellac is definitely crib safe, but from what I understand most common finishes are safe once they cure.
    15,811
    I like Shellac also, as it is totally food safe, in fact most pills have a coating of shellac on them so they don't fall apart in your mouth, and most chocolate is also coated with shellac, so you don't melt it when you touch it.
    The other nice thing about shellac, IMHO is that you can easily repair it down the road.
    doug, where it me i`d shoot cab-acrylic lacquer on it.....
    La Habra Hts. CA
    399
    Tod what exactly does cab-acrylic mean. I also don't do much finishing so don't have access to a gun.
    Doug
    it`s a catylized lacquer that must be sprayed....pretty durn tuff! i don`t like using it on stuff `cause it`s catylized but i doubt a 3-4y/o could hurt it let alone an infant......most of your higher end kitchens that are site finished have cab acrylic sprayed on `em.....there`s not much that`ll hurt it short of knifes or real hot stuff.
  1. The best/safe finish for a crib
    By John French in forum Finishing School
    Last Post: 03-27-2012, 05:15 PM
  2. Home bar, stools, and sofa table for my son-FINISHED, FINISHED, HOOORAYYY!!!
    Last Post: 09-18-2011, 03:36 PM
  3. Is this safe ????
    By Bob Gibson in forum Jigs and Fixtures
    Last Post: 06-19-2010, 02:10 PM
  4. safe?
    Last Post: 11-11-2009, 02:31 PM
  5. Kid safe finish?
    By Matt Dunlap in forum Finishing School
    Last Post: 03-23-2008, 07:11 PM
