Results 1 to 10 of 19
Thread: Titan Chuck.......?
    15,811
    Titan Chuck.......?
    OK, I think this is a no brainer, but I thought I'd check with you guys first.
    I have the Nova G3 chuck, I really like it, but it is smaller than the Super Nova 2, and I'm finding that I would like the extra capacity and stable qualities of a larger chuck.
    The G3 that I have
    Super Nova 2 a medium chuck
    Super Nova Titan, a big chuck
    I have three sets of jaws.....
    The 2" jaws that came with the G3 chuck
    these beefy 3" bowl jaws
    and these 3" long nosed jaws.
    Now all three sets will fit on the Super Nova 2 chuck or the Titan chuck, but I would think that with the Titan, I'd be looking at getting another set or two of larger jaws (the Titan 3 hole jaws are not really made for the G3 chuck).
    So you see it seems to me the only real question is to skip the medium sized Super Nova 2 chuck and just get the Titan, or should I get the Super Nova 2 and wait on the Titan?
    My thinking is that the Super Nova 2 and the G3 kind of overlap, while the G3 and the Titan do not......?
    Thoughts and comments please!
    North West Indiana
    6,108
    Buy the Titan, send me your old one and I will keep it from feeling lonely and discarded!!!
    Kutztown PA
    252
    What are you planning on turning Stu, or perhaps I should ask, what is the maximum capacity of your lathe? I remember reading about it way back when, but I have CRS. I think you have a DVR, right? I use my Oneway Talon with the #3 jaws to turn anything up to 16" or so with good results. That might be exceeding manufacturer recommendations, but I don't know, since I didn't read them. But I do know that I have been able to do it, and with some pretty aggressive cutting, without losing pieces off the lathe. Of course, if you need another tool, you need another tool, there is no question about that!
    Bill
    Bill Grumbine
    www.wonderfulwood.com
    how small does the bigun go down to? you can always put small stuff in a larger chuck but not vice-versa.
    15,811
    yes Bill, I have the DVR 3000.
    Well this is the thing, the Titan might be over kill, right? Not that I don't mind a little overkill
    Tod the Titan will take the standard jaws that came off the G3 chuck, so it will go down to the same small size as the G3, but it will go a LOT bigger too.
    One of the problems I'm having now, is that say for box making, I can't stick a square piece in the G3 chuck much over 3" square, so I have to put it between centers, turn a tenon and then chuck it up, with the larger capacity, I could run a larger square piece in the jaws without having to do the tenon thing, know what I mean.......
    15,811
    Hmmm, one more thing, I'd not thought of, they do sell a 4" jaw set that will work on the G3........
    4" Jaw Set On G3 Chuck
    Square Stock Mode
    Min 2.205"
    Max 3.031"
    Expanding Mode (Usual round tenon)
    Min 3.819"
    Max 4.646"
    Same Jaws on the Super Nova 2 chuck yield the same results.
    But on the Titan Chuck
    Square Stock Mode
    Min 2.205"
    Max 3.425"
    Min 3.819"
    Max 5.039"
    As you can see this gets confusing, but, if I have the Super Nova 2, then I can run the 5" jaw set.....
    5" Jaw Set
    SuperNova2
    Square Stock Mode
    Min 3.032"
    Max 3.819"
    Min 5.000"
    Max 5.787"
    Maybe all I really need is the Super Nova 2....
    I do not really plan on turning HUGE things.....yet....
    I see the Super Nova 2 at Woodcraft for $170, and the insert for another $25, while the Titan is about $270, with insert at Amazon (don't see if for sale at Woodcraft... ) so the difference is about $75....
    15,811
    Aw man....
    I found out that Craft Supplies is having a sale, it would be 20% off the price, and, they have the basic SuperNova2 chuck for $169.99 and the basic Titan Chuck for $164.99 YIKES!
    Both will need the $24.95 insert, but now that they are basically the same price.......which one do I get
    Jul 2007
    DSM, IA
    5,719
    Haven't you just answered your own question? I assume the 5" jaws work on the Titan as well with even larger square/expanding dimensions? The BIGGER for LESS! But wait....wouldn't the Titan cost more to run?
    North West Indiana
    6,108
    Jeff you were reading my mind! I was just going to type to Stu, well the 3 hp or 5 hp?
    San Antonio, Texas
    765
    Stu, of the two, I'd get the Titan. I ordered a new SN2 when I ordered my Mustard, but it had considerable runout. At first I thought it was the adaptor, but it turned out to be the chuck. I know, these things happen, but for the price... Anyway, I returned it for a refund and ordered the Barracuda4, and I have not regretted it one bit. Here's my main point: The B4 is a large chuck like the Titan and based on the kind of turning you do I think you'll be money ahead to go big.
    One thing of note on the B4 for the curious. The SN2 (and I assume the Titan) has a set screw to secure the chuck to the spindle so it won't accidentally spin free when you stop the lathe. This can be especially critical on larger turnings. The B4 does NOT have this feature (and that's the only negative I've found w/this chuck).
  1. Chuck T
    Last Post: 08-17-2012, 08:01 AM
  2. Donut Chuck used in Scroll Chuck
    By Dawson Mossman in forum Turning Tool Questions and Show & Tell
    Last Post: 12-21-2009, 09:59 PM
  3. Will this Flat chuck fit any other brand chuck?
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 07-03-2009, 07:33 PM
  4. That Chuck - What a guy!
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 07-27-2008, 12:48 AM
  5. Titan Chuck vs G3 Chuck
    Last Post: 09-26-2007, 06:37 PM
