Results 1 to 10 of 10
Thread: Tool cabinet structure . . .
    El Paso, TX
    146
    Once more into the unknown ! Just brainstorming. Without building seperate structures like commercial tool chests with a " mid-cabinet" and " top-cabinet" how do we support the upper level drawers over the full-width drawers in the middle ? I'm still working out " theory " in my head so my terms are probably lame !
    9,109
    40+ inches is pretty wide for a drawer. Have you considered making those two center drawers into a set of four? I think this would work astheticly as well as structurally(?)
    El Paso, TX
    146
    Was afraid . . .
    I was going to hear that so I kinda left it out. In my mind's eye I had planes on the bottom with the weight spread out between three draws and my heart set on two saw drawers in the middle section.
    9,109
    If you really want the 'look' of two drawers you could build the drawers narrower (32" is about the max) and use false fronts to get the look. This of course 'wastes' space but does give you the look you want.
    MX
    146
    For what it's worth Steve, I think Glenn's four door version looks more aesthetically appealing, but you are the artist, so in the end, you should make what YOU like.
    That said, I think Glenn's idea for the false door fronts is probably your best bet if you want to get the strength you are looking for.
    I have no affiliation with Glenn or Glenn's ideas. All my comments are based on my opinion and I receive no financial rewards for stating them.
    Houston, Texas
    2,323
    Quote Originally Posted by steve mackay View Post
    Hi Steve,
    Don't stop short! You want 40" drawers, then have 40" drawers.
    I think Glenn's design is quite nice, he is good at that stuff.
    Back to the 40" drawer. I have a piece of furniture with 1 - 41 1/2" drawer on the top. 4 drawers below that, each 20 3/4" + or - ,and then 2- larger drawers below those, also at 41 1/2". It can be done and you can do it!
    This is the wondrful thing with designing and building it yourself, you can do it!!!!
    Support is the correct term. My thinking is either support it from the top, suspended, or support it from the bottom of those compartments with a worthy member.
    You can do it just like you drew it. Think outside the box, whatever that means!!!!
    Please join me. Register now.
    Shaz
    Here is how
    El Paso, TX
    146
    Mr. Schaubhut . . .
    Good Lord, thank you ! THATS the push over the berm ! Had a revelation last night. If I could " sneak " a " lintel " ( maybe in the form of a frame ) over the two wide drawers them hide it behind wood faceing. Hmmmmmm. Wondering if this would be cheating enough to keep me up nights.
    Charlotte, NC
    1,487
    You could put sliding dovetails in for the verticals, which would lend the support from the top. Another idea is to make a thin torsion box for under the drawers.
    El Paso, TX
    146
    OK, I'll show my butt here . . .
    torsion box ? Your right. I had wondered how they do the old drawers that hold Printer's type. Seen a lot of them in antique stores now-a-days but never turned one over.
    Houston, Texas
    2,323
    Glenn, Allen, and Ed offer advise worth considering.
    Looking at your initial drawing on a semi split screen, it looks like you could ............................lower the bottom drawer fronts to leave about a 1/2" above the base.........................., then space the two long drawers equally between ( A ) the top of the large bottom drawer fronts and ........................................the ( B ) bottoms of the upper small drawer fronts. Considering you are only leaving 1/8" space between the upper drawers. I think you should continue the spacing between drawers all the way down................picking up enough space to add a "lintle" ( Good word you used! ) that can be hidden behind the drawer front itself.
    You can, you can
    Shaz
    Here is how
  1. Tool cabinet Tool Chest what belongs what dont
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 10-28-2013, 05:32 PM
  2. Benchtop Tool Cabinet
    By Kevin Vernon in forum Flatwork Project Showcase
    Last Post: 10-09-2013, 10:41 PM
  3. New tool cabinet
    By Jeff Horton in forum Flatwork Project Showcase
    Last Post: 12-24-2011, 10:06 AM
  4. Mobile Tool Cabinet
    By Larry Cronkite in forum General Woodworking Q&A
    Last Post: 09-09-2011, 03:03 PM
  5. hand tool cabinet
    By jim capozzi in forum General Woodworking Q&A
    Last Post: 03-18-2007, 04:16 PM
