Results 1 to 7 of 7
Thread: New mitre saw
    Sep 2007
    613
    New mitre saw
    I designed and build a new mitre saw for my segmented turnings.
    I have a mitre saw I bought a time ago in a do it yourself shop, but this thing works very bad, it's something like we say here in Holland, '' een waardeloos ding", in English, a worthless thing.
    I always make for my segmented turnings segmented rings excisting of 12 segments, so 30 degrees segments.
    I can now cut segments under an angle of 15 degrees on each side, and repeatable, by using a build up ruler, so all the segments are the same, that was my goal.
    The whole construction of the saw is almost made of aluminium, also the base.
    The round bottom plate is made of two pieces 1/2'' muliplex, and 8mm laminate, all glued together, so the surface is as flat as it can be.
    The guiding system excist of 4 hard wooden rollers with turned nylon linear bearings, mounted in steel inside tubes into the wooden rollers, so when I get wear out on the wooden rollers, they are easely to replace, by turning new wooden rollers. Everything is adjustable, the position of the rollers as well the cutting angle. I have to find out the right positions, by trying out.
    Next monday it's a try out day, anyway I saw a straight cut by trying out the saw. And more important, I had a lot of fun with making this saw.
    Attached Thumbnails Attached Thumbnails 100_1049 - mitre saw.jpg   100_1050 mitre saw - other view.jpg   100_1051 - mitre saw top view.jpg
    11,901
    Beautiful tool. And, I'm sure it is super accurate. Haven't noticed you here previously. If I missed you, a late "Howdy".
    1,289
    That's a beautiful tool Ad.
    Stu is going to love this one.
    DT
    15,815
    Oh my, that is NICE!!
    Don, you know me so well
    very nice ad!
    30,231
    That looks like a great solution to the problems you had with your old miter saw. Great job, Ad.
    Sep 2007
    613
    Hey guys,
    Thank you all very much.
    Today was a try out day, made 12 segments with straight cuts and of course the same size, so I'm happy.
  1. Compound Mitre Saw
    Last Post: 09-07-2011, 03:34 PM
  2. Any one still use their old mitre box
    By Darren Wright in forum Neander Tool Questions and Show & Tell
    Last Post: 01-09-2011, 11:23 PM
  3. Mitre jack
    By ken werner in forum Old Ads
    Last Post: 02-15-2009, 12:50 AM
  4. Mitre Saw Station
    By Malcolm Webb in forum Jigs and Fixtures
    Last Post: 09-17-2007, 02:19 PM
  5. Mitre saw stand
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 08-30-2007, 04:28 AM
