Chuck Beland
- Rhode Island
Well since I have 4 more ring bowls to do I thought I would first turn them all to finish including the foot. Then I could put back in the chuck to sand them all then put the poly finish on them one after another. Well I did just that & found out after you try to re-chuck it it's out of round at least by a 1/16" It took me by the 2 nd bowl of sanding to figure out what I did wrong.
I should have made the outside then sanded to completion then do the inside & sand to completion then start another bowl after all bowls were done all I would have to do would be put the poly on. I got 3 all done but the poly started. I used the expansion jaws to grip the good size opening & I had to use my small Sorby round scraper to try to true the inside again. For some reason the scraper dug in a bit & bowl came out of the jaws. all I did was ruin the foot I should be able to re turn the foot & finish the bowl.
I was just a bit disgusted with myself so I shut the light off & came on here.
Who wants to dry my tears & wipe my nose
Chuck
Chuck
