Results 1 to 6 of 6
Thread: Metalworking Lathe
    La Habra Hts. CA
    399
    Metalworking Lathe
    Need to get a metal lathe for fabrication of of parts for my concrete trowling machines. Anybody know a good brand? I need something to start with in my research.
    Doug
    bruce page please pick up the courtesy phone....
    La Habra Hts. CA
    399
    I'm assuming that Bruce is somebody that knows something about metal lathes? If so please chime in?
    Doug
    Albuquerque, New Mexico
    1,099
    Doug, new or used? What size? Like wood lathes, the bigger the swing the bigger the $$.
    A good South-Bend or Atlas lathe would be a good choice in the ~10” swing range.
    A local dealer is selling a South Bend for 2K that’s pretty well tooled but I have seen them go for $800.
    http://www.abqtool.com/inven/southbe....heavy.10.html
    friend...if you have one."
    one."
    I use a Cincinnati #19 lathe at work. It does accurate work and has had a very hard life. It's not a CNC lathe though which can be a major drawback. Still it turns threads just fine, does tapers just fine and I have successfully turned balls and other standard metal working processes on it.
    I am not sure what the value is. This one is pretty old, but it works quite well and is always in use. In fact we often jockey for position in front of it for making our boat parts.
    here`s an old "craftsman" branded atlas that i use to make parts to keep my stuff runnin`....they can be found pretty cheap if it`s big enough for what you want?
  1. OT Metalworking Again - Chopsaw Mod
    Last Post: 11-17-2013, 02:17 AM
  2. Some More Metalworking.... going to brag a bit....
    Last Post: 11-05-2013, 04:27 PM
  3. Some Metalworking
    Last Post: 11-02-2013, 09:00 PM
  4. Midi Lathe/Stand setup... aka help me set up lathe land in my shop.
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2012, 06:41 PM
  5. Metalworking chuck conversion
    By curtis tolbert in forum Turning Tool Questions and Show & Tell
    Last Post: 06-22-2008, 12:26 PM
