Results 1 to 4 of 4
Thread: Need router bit
    Need router bit
    I am looking for an upspiral carbide bit, 3/8" dia x 1/4" shank. I checked all the catalogs and none are listed. They list 3/8" and 1/2" shank, but no 1/4". Can anyone help me?
    9,109
    I have never seen one. Spirals are solid carbide and I'm not sure a large head on a small shaft is a good idea with solid carbide(?). You will be able to find a 3/8" shear-cut with a 1/4" shaft; CMT and others have these. Is this for a laminate trimmer? If a 1/4" collet regular router, could you make multiple passes?
    Austin, Texas
    1,461
    I don't know about this request, but when I have challenged the folks at www.woodline.com they have always been willing to custom make a bit for what I consider in-stock prices and service.
    I also am concerned about a solid carbide bit (brittle) with a larger diameter on a 1/4 inch shaft.
    Charlie Plesums, Austin Texas
    Odessa, Tx
    1,813
    Small Correction/Clarification
    I must point out that not ALL Spiral bits are Carbide, they are also many made from HSS, but I still don't think I have ever seen any spiral bit where the cutting part is a larger diameter than the shank.
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 04:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Replies: 0
    Last Post: 09-01-2010, 05:29 PM
  4. Router Table Router and Lift
    Last Post: 10-08-2008, 06:21 AM
  5. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
