Results 1 to 6 of 6
Thread: Need router bit
    Need router bit
    I am looking for an upspiral carbide bit, 3/8" dia x 1/4" shank. I checked all the catalogs and none are listed. They list 3/8" and 1/2" shank, but no 1/4". Can anyone help me?
  2. Ronald,
    With solid carbide the cut diameter should always be less than or equal to the shank diameter. To make a bit like you describe would result in a bit that would break if you looked at it wrong. Better to stick with 1/4" cut diameter and make two passes.
    UPcut spiral router bit
    Quote Originally Posted by Charles McCracken View Post
    Ronald,
    Charles, I am trying to build a pocket hole cutter from plans in "Shopnotes". The author claims a 3/8" straight bit doesn't work, but he switched to a spiral up-cut bit and it worked great (he claimed). Cutting pocket holes 3/8" wide, shouldn't require too much power, so a 1/4" router should be adequate. I think a 1/2" router, not only more expensive and large, would be "overkill" for this job. I don't know where the author got his bit from and if he used a 1/4" or 1/2" router. HSS would work OK.
    ronald, the p/c pocket cutter i use has a 690 spinnin` the 3/8 bit and a laminate trimmer spinnin` the pilot bit......the 3/8 bit is a 1/2" shank straight bit.
  5. Ronald,
    You may be correct that a 1/4" shank router would push the 3/8" bit (although when you get to the full depth of the pocket you are removing a lot of material) but you would likely have to try to find a HSS end mill to get the dimensions you want.
    Thank you all for your responses. I now have a clearer picture.
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 04:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Replies: 0
    Last Post: 09-01-2010, 05:29 PM
  4. Router Table Router and Lift
    Last Post: 10-08-2008, 06:21 AM
  5. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
