Results 1 to 5 of 5
Thread: Carcas saw . . .
    El Paso, TX
    146
    Carcas saw . . .
    I'm familiar with the term carcas just enough to throw it around in general and I think Mr. Wenzloff's saw in LV is too cool for school BUT . . . what does the design of the saw do that makes it a " Carcas Saw " ? Just feel the need to learn something tonight !
    Jun 2007
    Texas
    18
    Dunno for sure myself, however, borrowed from the Lie Nielsen site;
    Carcass Saw
    The Carcass Saw is used for precise cuts across the grain, cutting tenon shoulders, and defining the edges of a dado. It has 14 points per inch, filed crosscut, for cutting quickly, yet accurately and smoothly. Blade is .020" thick, with a .003" set. Overall length, including handle, is 16", with an overall height of 4-7/8". Usable blade dimensions are 11" long by 2" deep. An ideal complement to the Dovetail Saw.
    El Paso, TX
    146
    Oops, WAY sorry ! I guess what I'm looking at is . . .
    His " Half-back " saw. Its the one with the short spine and rounded nose.
    See ? Mighty confusing !
    30,230
    This article has a lot of good information, but unfortunately it doesn't have the answer:
    http://www.vintagesaws.com/library/f...97/fall97.html
    Then I found this, deep in the text of this page:
    Carcass saws are large dovetail saws. They cut dovetails in the corners of a carcass. The carcass is bigger for thicker stock, and slightly rougher work (you usually cover these dovetails with moldings).
    (I always wondered what carcass they were talking about, too.)
    El Paso, TX
    146
    OK, learned more than I barganed for ! . . .
    I stmbled on this one but its excellent ! " Norse Woodsmith ". VERY good ! Also, hes got a sense of humor like Patrick's B & G. Well worth checking out !
