Results 1 to 10 of 15
Thread: Why Would The Delta 20" Drill Press NOT Be A Good Choice?
    Treasure Island FL
    92
    I am researching a new Drill Press. I have looked at the new Delta 20" introduced at the Atlanta show, but its availability keeps getting delayed - now sometime February or March '07. I like its 6"+ quill travel. The new Powermatic 2800 is out and available. However, the Delta 20" 70-200 has been out for a while and looks substantial. After reviewing its features below, what does it lack to be a solid addition to a woodworking shop?
    20" 1HP 120/240V Drill Press Model 70-200:
    Speed Range: 150-2200
    Chuck Taper: Jacobs 3
    Quill: Diameter - 2 7/16"
    Quill Stroke: 4 3/4"
    Capacities: Key chuck= 5/8"; chuck to table= 24 1/2"; chuck to base= 44"
    Overall Dimensions: 67" tall; 18 1/2" wide; 34" deep
    Weight: 345 lbs.
    Quill Travel: 4 3/4" step pulley or variable speed
    Motor: 1HP 120/240V, single phase; 60 Hz.; 1720RPM
    Spindle Speeds: 150, 260, 300, 440, 490, 540, 1150, 1550, 2200
    Table: Cast-iron, production type with clamping slots and coolant trough; 18 3/8" x 16 1/8"; tilt= 0 to 45 degs left and right
    Column Diameter: 3 5/8"
    Spindle Taper: #3 Morse Taper
    Thank you for your input.
    Jeff Wright
    Treasure Island FL
    4,992
    jeff, what are you wanting to do with a drill press? i`ve got by with the 17" tai/chi units for years in a woodshop......20" is nice! but do you need(or want) the extra deapth and associated costs? tod
    Treasure Island FL
    92
    Tod, I will be building cabinets and furniture (and maybe an occasional small boat). But I also suffer from the syndrome of wanting to buy my last piece of equipment first and not being frustrated with a tool inadequate to do the job. If spending a couple hundred extra will help insure satisfaction, I figure it's money well spent.
    Jeff Wright
    Treasure Island FL
    4,992
    jeff, if money is less of an issue than function...then go for the longest quill stroke available, 1 hp or greater motor, a large square table.......then throat depth.........then if you`ve not broke the bank and changing belts bothers you look at variable speed.............if ya` ain`t skeered yet , then look at the "gearhead " units.........some of these compare price wise to used bridgeports! which is the next step up.......and may be an option if you don`t mind used machines? older bridgeports that are worn for metal working have tighter tollerances than most new drill presses plus have x-y tables, deap throats and tons of power.........something to think about? tod
    Treasure Island FL
    92
    [quote=tod evans;5883]if ya` ain`t skeered yet , then look at the "gearhead " units.........some of these compare price wise to used bridgeports! which is the next step up.......
    Tod,
    1] What's a gearhead unit?
    2] Any hints about where I might find a used Bridgeport for sale?
    Thanks for your input . . . good info.
    Jeff Wright
    Treasure Island FL
    4,992
    jeff, here`s a link to the gearheaded units carried through amazon;
    http://www.amazon.com/s/ref=nb_ss_hi...ad+drill+press
    for a used bridgeport? look local `cause they`re heavy! maybe a machine shop upgrading, or one going out of business......used equipment dealers....
    bridgeports are really cool machines! if a person knows how to run one well he can build just about any tool in the shop with one.......but they`ll kick butt as a drill press .......tod
    8,435
    Jeff,
    While not a Bridgeport here's a lead on a Clausing in Tarpon Springs.
    http://tampa.craigslist.org/tls/232919649.html
    The older Clausing are very nice machines also and would do a bang up job as a precsion drill.
    8,435
    Jeff,
    If you've never seem one before here' is a picture.
    688
    Good thread. I think this thread really makes the point that links add value to the forum.
    4,992
    don, clausings are darn nice machines too! if the guy on craigs list is including some tooling?( it`s worded like he is) that`d be a potential steal.....
    more food for thought eh jeff
  1. Replies: 0
    Last Post: 02-09-2015, 03:55 PM
  2. Delta Reeves drive drill press adjustment help
    Last Post: 04-01-2014, 04:39 PM
  3. delta mortiser attachment for drill press
    By allen levine in forum Classified Ads
    Last Post: 03-15-2013, 07:59 PM
  4. Delta Drill Press CL New Jersey
    By Jim Mattheiss in forum Hot Deals
    Last Post: 07-08-2008, 12:09 AM
  5. Delta drill press, xlnt condition, 4 sale
    By Jim C Bradley in forum Old Ads
    Last Post: 06-16-2008, 05:42 AM
