Results 1 to 2 of 2
Thread: Lock command? (SU)
    The Heart of Dixie
    4,268
    Lock command? (SU)
    Getting more details in SU. Had the thing close to be being done and I find the base of the unit is slightly off. Someone how I moved a part without knowing it. Never could fix it and just had to delete the base and start over.
    Looking in the menu (I have to 5.0 BTW. 6.0 makes my screen go black.) I see lock command. Exactly what does it do?
    Custom built boats and Kits
    SE Minnesota
    2,550
    Jeff, locking a component or group makes it so you can't inadvertantly change it. You can't edit it or move it without unlocking it first. It might be a good solution to prevent goofing things up.
    FWIW, you can also revert to an earlier saved (manually or auto-saved) version. Depending how much you've changed the model since the last save, or how long ago you made the error, reverting my help you avoid having to start over.
    And finally, if you screw up a component or group, temporarily save the current file using Save as and give it a new name (Entertainment Center b). Open a new session on SU and open the previous version of the file. Copy the component and paste it in the newer version. Use the old version to replace the screwed up version.
  1. Finally got the hang of the 'intersect command'
    By Brent Dowell in forum Designs, Plans and Sketches
    Last Post: 12-25-2012, 06:43 AM
  2. Lock Your Cars!
    Last Post: 08-17-2012, 04:57 PM
  3. spindle lock
    Last Post: 10-24-2010, 07:42 PM
  4. Thermostat lock
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 02-22-2008, 10:08 PM
  5. Taper Lock
    By Jr Strasil in forum Neander Tool Questions and Show & Tell
    Last Post: 01-21-2007, 01:29 AM
