Results 1 to 3 of 3
Thread: pics!! Ryobi AP1300 dust collection
    Sep 2007
    Central (upstate) NY
    1,457
    My Ryobi planer couldn't keep it's dust collector / vacuum attachment shroud in place. Every time I hooked up the DC hose to it, the thing would start slowly sliding off.
    What I did was to buy 1/2" longer set screws than what came with it, as well as appropriately sized fender washers, external start style lock washers and some SAE washers for the new set screws. Every screw was put in so that one of the lock washers contacted the plastic. Between the lock washer and the bolt head was placed a fender washer or a SAE washer (SAE if fender was too big).
    I haven't used the DC hookup a lot since doing this, but have walked into the DC shroud quite a few times trying to "mountain goat" over to the new lathe. I figure my 300# frame smacking into the part is similar to hooking up the DC. Anyhow, the shroud is still firmly in place, so I'm sharing this tip in case others have the same issue.
    Here are the pics:
    As can be seen, I retained the original bottom handled screws and used fender washers over the external star lock washers (used to "bite" into the plastic shroud). On the top i bought slightly longer cap screws and used SAE washers with the external star lock washers.
    15,806
    Sorry Mark.............. no pics............... didn't happen
    Seriously, sounds like you fixed it, and some pics would be good!
    Sep 2007
    1,457
    Doh!
    I'll rectify this sometime soon. There won't be any before pics, as I'm not going to go back to the drooping DC hookup.
  1. Dust Collection
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 08-13-2011, 08:19 PM
  2. Ryobi dust collector
    By Carol Reed in forum General Woodworking Q&A
    Last Post: 07-07-2011, 12:33 AM
  3. Ryobi router dust collection-?
    By Dave Hanson in forum Jigs and Fixtures
    Last Post: 02-01-2010, 11:22 PM
  4. dust collection
    By J W Seals in forum General Woodworking Q&A
    Last Post: 10-31-2008, 03:12 PM
  5. My old ryobi table router has bit the dust
    By Jim Hager in forum General Woodworking Q&A
    Last Post: 01-13-2007, 01:01 PM
