Results 1 to 10 of 15
Thread: Calling the Spindle Turners.........
    What is the difference between a "Spindle Gouge" and a "Detail Gouge"
    Detail Gouge
    Spindle gouge.
    My cheapy tools are just about done, so I want to replace them, should I get the detail gouges or spindle gouges?
    Thoughts?
    Stu....the reference material I have.....the spindle gouge can be ground to a the detail gouge form. It's sharper pointed that allows it to get into tigher corners. I have a 3/8" spindle gouge ground to a "detail gouge" shape and it allows me to get into crevices that it wouldn't get into if it had the standard grind.
    Ken
    North West Indiana
    6,099
    Guess that means I am not a spindle turner!!!
    Thanks Ken, that is kind of what I suspected.
    566
    Stu, my understanding is that the main difference between spindle gouges and detail gouges is the amount of steel left under the flute. More steel under the flute allows you to grind a longer bevel on the end and create more detail while using the long point in some ways that emulates a skew.
    I use detail gouges in a variety of ways. I have a couple of detail gouges from Packard Woodworks. One has a long bevel and the other has a short bevel. I use the long bevel for exterior shaping of some of my boxes that have globular shaped bodies. The one with the short bevel I use for hollowing and cutting end grain. More steel under the flute allows me to reach farther into the body of the box when I am hollowing and have less vibration.
    My favorite detail gouge for hollowing is the Henry Taylor 1/2" which really has a lot of steel under the flute and allows a full cut with the shortened bevel without any chatter. I use it for rough work and then do the fine work with the Packard tool. I like the shape of the flute on the Packard tool for clean up inside a box better than the Henry Taylor.
    The other detail gouge I have is the 5/16" P&N I use with a long bevel to reach into areas where the size of the other gouges would prevent access. The long grind on this P&N really is a substitute for a skew. I can peel off shavings of end grain that resemble frog hair!
    I do not know if this is how detail gouges are supposed to be used but this is how I have adapted them for doing what I want to do for turning boxes.
    I am contemplating pulling the trigger for the Doug Thompson 7/16" detail gouge that has a really shallow flute and see how it does for hollowing. If I don't like it I will regrind it at a long bevel and use it for detailing. Now that is an original thought.
    Here are some pictures of three of my detail gouge grinds. In the first picture with the side view from top to bottom is the Henry Taylor 1/2" and then the Packard 1/2" both ground for hollowing. The one at the bottom is the Packard 1/2" ground for work on the outside of a box as a traditional detail gouge. The second picture has the tools in the same order but shows the difference in the flutes. The narrower Henry Taylor flute really makes for a great hollowing tool.
    Attached Thumbnails Attached Thumbnails Detail gougepics2 (445 x 400).jpg   Detail gougepics3 (400 x 400).jpg
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    Thanks Mike, when you are saying "more steel under the flute", you are really saying a very shallow flute, right?
    566
    Yessir, in my long winded convoluted way that is exactly what I was trying to say.
    Sorry.................................
    Quote Originally Posted by Mike Stafford View Post
    No no no, long winded is good, more info that way!
    I've got one of Doug Thompson's 3/8" shallow detail gouges, and it's handier than I expected it to be. I use it more than I thought I would.
    Goodland, Kansas
    4,834
    Stu I would get both. You will use them both. I use a regular spindle gouge for roughing stuff and then I like the little 3/8" detail gouge for fine work and like Mike to finish the inside of boxes.
    Bernie W.
  1. Calling Dan
    Last Post: 01-04-2010, 09:41 PM
  2. calling all segmented turners!
    By Bill Lantry in forum General Woodturning Q&A
    Last Post: 11-09-2008, 04:32 PM
