Results 1 to 10 of 15
Thread: vise jaw material
    Sep 2007
    Central (upstate) NY
    1,457
    vise jaw material
    Is there any reason not to use softwood jaws for a bench vise?
    only that they`ll need replaced more frequently......
    5,317
    Quote Originally Posted by Mark Kosmowski View Post
    Mark,
    I use poplar for mine. Not as soft as pine, spruce, or aspen, but still pretty soft. Mine are half an inch thick, and I've imbedded two neodymium magnets in each so that they stay in place during use, but can be easily removed if necessary.
    I used to have one set that was faced with cork, but the cork got torn up fairly quickly, and I just never bothered replacing it.
    I used beech which is not expensive around here. It's pretty hard but not so hard as to damage things. My vises primarily hold dogs to tighten against dogs in the bench so I needed a material hard enough to hold the dog without wearing out. If you're clamping items between the jaws, other than the wear-factor I see no problems.
    I pad my vice Jaws with copper. It works like steel, lasts like steel and is as soft as wood. Works good for me.
    5,533
    pssst Mark....
    M
    A
    P
    L
    E
    -Ned
    Quote Originally Posted by Travis Johnson View Post
    I pad my vice Jaws with copper. It works like steel, lasts like steel, costs like GOLD.... and is as soft as wood. Works good for me.
    Seen the price of copper lately
    I use whatever hard wood I have around that is the right size etc.
    Sep 2007
    1,457
    Isn't 24K gold cheaper and softer than copper now? Good for those gilded age pieces.
    My original question was me thinking of replacing my current oak jaws to mount dogs (old jaws were only 3/4" thick, dogs need 3/4" hole). What I did was to add a piece of 2 by 4 offcut to the back of the rear jaw. I should be able to get pics tonight.
    It seems like all of my self made shop improvement bits are offcuts from Ned's shop construction lately....
    Jul 2007
    DSM, IA
    5,719
    And he thought he was getting "free" labor out of you.
    My Website
    Copper has somehow got this reputation for being overly expensive, but the cost is dropping. I have bought a lot of copper lately, a few hundred feet of copper tubing for my propane heating system, and a few sheets for my cupola. At work we use it all the time and it runs about 60 bucks for a 3 foot by 8 foot sheet, 20 gauge.
    This cupola cost about 100 bucks...
    Besides, if you see a plumber or a tin knockers shop, they would give you the scraps you need to make some copper jaws. Not arguing with anyone here mind you, just saying copper can be had and it works good.
  1. Recall material?
    Last Post: 02-21-2016, 11:19 PM
  2. Looking for non-skid material
    By Matt Ducar in forum General Woodworking Q&A
    Last Post: 12-11-2011, 02:04 AM
  3. I need some reading material
    By Karl Brogger in forum General Woodworking Q&A
    Last Post: 10-28-2011, 01:11 AM
  4. sled material
    By Rex Bloem in forum Jigs and Fixtures
    Last Post: 03-08-2009, 12:10 AM
  5. Tail Vise VS Shoulder Vise
    By Rich Aldrich in forum General Woodworking Q&A
    Last Post: 10-30-2008, 12:44 AM
