Results 1 to 5 of 5
Thread: planing figure
    11,899
    planing figure
    I bought some ash today for planned large plaque. One end has a lot of figuring, very pretty. But when I ran this through the planer.....wadda mess. The figuring tore out and left craters like moon rock. Didn't matter which direction I ran it through, crater city. Is this to be expected with highly figured wood and a planer.
    Zushi, Japan
    739
    Frank,
    In Japan we have Japanese ash, called tamo. When it is highly figured it often has a peanut shell pattern in the grain structure. One general rule with this wood is don't run it through the planer unless your blades are very sharp and you take very light cuts. And even then you are likely to get tearout. If possible run it through a drum sander.
    Indiana
    224
    Thought I read somewhere if you dampen the wood before running it through the planer, it would help alleviate some of the tearing and ripping.
    Maybe someone else can comment on this.
    frank i know a fella with a widebelt who`s not far
    11,899
    Thanks. With sanding, I got it to an acceptable condition. But now, I'm regretting not studying the wood closer before cutting. The board is 10" wide and the figure lasts about 18". I could have gotten a bunch of nice pen blanks from that part. Oh, well.
  1. Can you help me figure value of the Delta Q3 scroll saw.
    Last Post: 09-14-2013, 07:47 PM
  2. Go-Figure
    Last Post: 11-21-2011, 12:56 PM
  3. How do you figure out how much you charge?
    By Brian Altop in forum General Woodworking Q&A
    Last Post: 01-15-2011, 06:08 PM
  4. I just can't figure Amazon out...
    By Jim O'Dell in forum Off Topic Discussion
    Last Post: 07-04-2008, 02:16 PM
  5. figure in wood
    By Chris Mire in forum General Woodworking Q&A
    Last Post: 01-23-2008, 03:23 PM
