Results 1 to 10 of 18
Thread: Bed BOLT Cams, anyone used these
    Kansas
    417
    I saw these and wondered if anyone has used them?
    http://www.rockler.com/product.cfm?O...Select=Details
    Thought they might be a good alternative to a bed bolt where you don't want to hide the bed bolt with a bolt cover.
    Rise above the rest
    Central NY State
    3,374
    Aaron, I have not used the bed cams, but looking at the Rockler info, it looks like it is screwed into the post.
    I've built a few beds, and the forces involved in holding the side rails to the posts are formidable. I am not convinced this product will hold up for the life expectancy of a bed.
    I like to make a mortise and tenon joint, held together with a very heft bed bolt from Horton's Brasses. The strength is really satisfying. True, one needs to have the bolt cover, but to me, that is just a constraint of dealing with a time-honored and proven design.
    Ken
    Charlotte, NC
    1,487
    Whew...I thought this was going to be a dirty post!
    looks like another way to do it. I haven't built a bed and can't offer much thought to the product.
    2,784
    I'm with Ed. My first thought was: "No. A little too kinky for me".
    Does anyone still make a bed side frame rail that has hooks on the end that slips into a receptacle that mounts in a mortise in the headboard and foot board legs, then drops down to secure it? I remember a bed growing up that was built that way, and it was always very very sturdy. Of course, it requires you to have a foot board. But would be perfect for a sleigh style bed. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Kansas
    417
    I thought it might be a little weak, I thought about regular bed bolts but the bed bolt cover would no look very good. The bolt covers would be on the end of the footboard, so those would show the headboard wouldn't be a problem since it would be against the wall.
    I am just not sure they would look good, so I may just use the the metal slip over bed fasteners, like these shown below.
    Rise above the rest
    Central NY State
    3,374
    I tried these once, and they wor
    ked ok in a low torque foot, but were wobbly in the headboard.
    http://www.rockler.com/product.cfm?p...bed%20hardware
    Nice looking bed you're planning.
    Stockport, England
    161
    This is a similar but better system; the luna washer and nut replace the cam and you simply tighten up the joint with a small spanner.
    http://www.scfhardware.com/j-shop/section.php/14/0
    I've used this system many times and it is the best concealed bed fitting I've found.
    I've also used the other one you pictured and find they work loose in time. Strictly for beds used for sleeping only!
    The Heart of Dixie
    4,268
    Quote Originally Posted by Jim O'Dell View Post
    Yup, that what I used on the bed I made a few months ago. I can't remember where I got them but they are still out there.
    Custom built boats and Kits
    Kansas
    417
    Here is a pic I found online, would make for some very clean connections, and the tabs are tapered so you would think it could wedge itself pretty good and hold tight over time.
    Rise above the rest
    Kansas
    417
    Quote Originally Posted by ken werner View Post
    Ken
    They show the cams being used in conjunction with dowels, would those dowels help take some of the support forces???
    I wouldn't glue the dowels since I want to be able to knock down the bed but at least they would be there to help support the bed along with the cam. Thoughts?
    Rise above the rest
  1. Bolt Action Pen
    By Bill Arnold in forum Lathe Project Showcase
    Last Post: 07-30-2015, 02:55 PM
  2. First Bolt-Action Pen
    Last Post: 09-12-2014, 04:18 PM
  3. 30-06 Bolt Action
    Last Post: 05-06-2014, 08:32 PM
  4. Drawboring with a lag bolt
    By Dave Black in forum General Woodworking Q&A
    Last Post: 03-14-2010, 06:08 PM
  5. Make a Nut & Bolt
    By George Watkins in forum Tips and Tutorials
    Last Post: 05-07-2009, 07:58 PM
