Results 1 to 6 of 6
Thread: Planer gauge for repeatability
    The Heart of Dixie
    4,268
    I saw this tip linked in another forum.
    Planer gage While I am not a big fan of dial indicators in woodworking this is nice application I think. A bit overkill but it is simple to build.
    While I would have to try it and see how it actually worked, if I could mount it with a couple of strong magnets and it wouldn't move, this could be sweet!
    I find that I am often having to plan a little more wood and this would be quicker than just trial and error.
    Custom built boats and Kits
    11,825
    Neat idea. I printed it out to keep and try.
    Oct 2007
    Pacific Northwest
    59
    Before I went digital, I had a long-travel dial indicator mounted on my old 4-post planer. It took care of all thicknesses up to 2" for $20 + some time figuring out a mount. (Grizzly G9809) I don't have a pic, but it mounted to the table and had a contact point that fastened to the base. That way, it read higher as the table was lowered. Worked fine until I forgot to remove it to run some stuff on edge that was over 2" -- kill one indicator...
    -JR
    The Heart of Dixie
    4,268
    John, what I had in mind was just being able to repeat a setting. Not so much measure the thickness. I had this happen just recently. I milled the lumber and then had needed one more piece that same thickness. I can do it but I have to sneak up it and it takes time. Just zeroing it out and leaving it till I am done with that project appeals to me. Then put it back in the case till my next bigger job.
    Albuquerque, New Mexico
    1,099
    Iím working on one for my Woodmaster as we speak. Iím using an older 2Ē travel indicator and Iím incorporating a fine adjustment but itís basically the same idea.
    The indicator Iím using is industrial grade with ruby bearings. I wonder how the cheap Chinese (HF) units would stand up to the vibration.
    friend...if you have one."
    one."
    Punta Gorda, Florida
    902
    Good tip. Thanks Jeff!
  1. Osprey Calibration and repeatability testing
    By Leo Voisine in forum New Systems and Builds
    Last Post: 03-22-2016, 12:12 AM
  2. Used a .410 Gauge
    Last Post: 12-19-2013, 10:53 PM
  3. Replies: 0
    Last Post: 04-16-2012, 01:43 PM
  4. Marking gauge conversion kit to mortise gauge
    Last Post: 09-03-2010, 03:55 AM
  5. 12" x 12" Auto Planer Wood Planer
    By Jim Burr in forum Hot Deals
    Last Post: 11-13-2008, 02:18 PM
