Ok, I'm getting close. I need to enclose the 3 open sides of the base. Not so much for beauty as for solidifying the base to reduce the racking if I push on it hard. My first thought was to use 3/4" oak veneer plywood. And I think that would be best, but it might be a little expensive too and with the new job, I'm a little low on shop funds at the moment. Could I use laminate flooring? Glue up a panel and screw it down? Would this be stable or would it expand/contract differently than the rest of the material I already have in this thing? (base is made of oak or ash legs, 3/4" oak veneer ply, and a few oak solids for the drawer rails) I will be out today for a Celtic Festival, and could go by the surplus builders store for some cheap laminate if that will work. Could stop by to see if HD has some damaged oak ply they will sell cheaper. Thanks! Jim.
http://familywoodworking.org/forums/attachment.php?attachmentid=13233&d=1191806886
ok, why does this not show a clickable link to enlarge, or just show the larger picture?Oh, well, you can get a larger view in my shop rehab thread, last post. thanks!
