Results 1 to 1 of 1
Thread: FS: Delta 6" Jointer DJ160 - SoCal - SOLD
    This JT160 jointer has served me well for occasional requirements over the last 2 years. This tool was used for small pieces and does an excellent job. It has been adapted for a 4” dust collection port but can be returned to the stock rectangular port by loosening 4 original screws. Current knives are fine. Here’s the specs:
    · Motor: 10 amp, 120V, AC, 60 hz
    ·Cut Capacity - Width: 6-1/8" (156 mm)
    ·Cut Capacity - Depth: 1/8" (3 mm)
    ·Cutterhead Speed: Variable-Speed 6,000 to 11,000 RPM 12,000 to 22,000 CPM
    ·Number of Knives: 2
    ·Table Size: 6-3/16" x 30" (157 mm x 762 mm)
    ·Table Height: 13-1/2" (343 mm)
    ·Fence Size: 4-1/4" x 19-3/4" (108 x 502 mm)
    ·Fence Tilt: 45° out
    ·Fence Positive Stops: 90° and 45°
    ·Dust Port Diameter: N/A
    ·Width: 18" (457 mm)
    ·Height: 13-1/2" (343 mm)
    ·Length: 30" (762 mm)
    ·Weight: 35 lbs (16 kg)
    Street price is around $220. Asking $160 with a new set of extra knives and push blocks.
    Riverside, CA area in zip code 92557
  1. Delta 6" jointer
    By paul newton in forum Old Ads
    Last Post: 02-10-2011, 11:42 PM
  2. *** Sold *** 6" Jointer in California
    By Dan Gonzales in forum Old Ads
    Last Post: 07-20-2009, 05:09 PM
  3. FS: 6” jointer, Delta 37-195, DFW area (sold)
    By Mike Forsman in forum Old Ads
    Last Post: 01-04-2009, 06:57 PM
  4. Delta DJ-30 12" Jointer
    By Stuart Ablett in forum Hot Deals
    Last Post: 05-07-2008, 04:30 AM
  5. FS: Delta 40-150 15" Scrollsaw - **SOLD**
    By Doug Shepard in forum Old Ads
    Last Post: 01-28-2007, 08:44 PM
