Results 1 to 10 of 10
Thread: Beall Wood Buffing
    Zushi, Japan
    739
    Beall Wood Buffing
    Sometimes I'm a real slow starter. I bought the Beall buffing system quite some time ago but never got around to using it till last night. What a difference it makes.
    30,002
    Yeah, it sure makes getting a nice finish a lot easier. One of those "how did I ever do without it?" things.
    Goodland, Kansas
    4,834
    Really makes a piece of wood or finished wood pop doesn't it.
    Bernie W.
    Fort Worth, Texas
    241
    Agreed. I love my Beall.
    Al, have you launched a bowl yet while buffing? You haven't had the full Beall experience until that's happened at least once. Tripoli is the worst grabber for me.
    I'm up to three launches. It's amazing how fast they can travel!
    I may be lost but I'm making good time!
    Three Seasons Woodturnings
    Zushi, Japan
    739
    Neal, thanks for the heads up on that. I did notice it had quite a pull to it while buffing it. Nothing worse than destroying a bowl in the final stages.
    Fort Worth, Texas
    241
    I made the mistake of presenting the rim edge-on to the buff. It was out of my hands so fast I didn't even realize what happened until I heard the BANG on the other side of the shop.
    Even knowing what I know now I've still had it grab two other pieces. One little slip in concentration is enough to do it.
    You're right. Ruining a piece in the final stages is the most heart-wrenching.
    Jul 2007
    DSM, IA
    5,719
    I will soon have a buffing wheel....what time of buffing compound do you all use the most?
    My Website
    Fort Worth, Texas
    241
    The Beall kit comes with Tripoli, White Diamond, and Carnuba Wax. On most woods you would use them in that sequence. You can get them from Beall or anywhere that sells buffer wheels.
    You don't want to use the White Diamond on dark woods with open pores, however. The silicates (or whatever they are) get into the pores and give the piece a milky film look. It will ruin a good finish.
    Jul 2007
    DSM, IA
    5,719
    Neal, is it necessary to use all three? I won't have a 3 wheel system and wondered if there is one that works as a good finish on antique oil, danish oil and/or toungue oil finish as that is what I use.
    My Website
    Fort Worth, Texas
    241
    No reason to use all three if you don't want to. Most of my work gets all three but it depends on the wood. I use Seal-A-Cell on nearly everything I turn and usually buff with at least Tripoli and wax. Some just get wax.
    The Cocobolo HF in the attachment below was done with no finish at all. Just buffed with Tripoli and wax (although technically, that is a finish). It did just fine on those two compounds.
    Occasionally I'll apply SAC and Arm-R-Seal (a high gloss urethane coat). Buffing these pieces with just wax gives the Arm-R-Seal coat a real polished look.
    As you can see, you can do it any way that works for you.
  1. Best oil to use with the Beall Wood Buff System
    By Jim Krager in forum Finishing School
    Last Post: 12-07-2011, 04:57 PM
  2. Beall Buffing System or something else?
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 07-18-2011, 04:50 PM
  3. BEALL Woodfinishing Kit
    By Jiggs Elphison in forum Finishing School
    Last Post: 06-28-2009, 08:43 PM
  4. Beall Pen Wizard
    By Jonathan Shively in forum Turning Tool Questions and Show & Tell
    Last Post: 12-25-2008, 01:17 AM
  5. Beall Buffing Lacquer
    By Cody Colston in forum General Woodturning Q&A
    Last Post: 08-14-2008, 02:16 PM
