Results 1 to 10 of 12
Thread: New low cost idea for wind power
    Nanaimo B.C. Canada
    131
    Lightbulb New low cost idea for wind power
    Here is a video showing some cool new technology for generating electricity from wind ->
    http://www.popularmechanics.com/tech...html?series=37
    This guy thinks outside the box, very bright
    Cheers! - Jim
    Wisconsin Dells, WI
    485
    That is really great. I'm guessing that this set up for harnessing wind power could be less obtrusive than that of the huge wind turbines.
    I just wonder how long it will take to bring this to market, or will current technology find a way to bury it in the sand, so to speak.
    Karl
    30,014
    That's brilliant. Elegant in its simplicity. Thanks for the link.
    Freaking brilliant, that guy deserves a gold star or two!
    11,828
    Definately outside the box thinking. Did he just give away a potentially very profitable patent idea?
    Melbourne, FL
    472
    Flutter
    Nice post.
    Just so happens I am looking into a small Savonius Rotor wind generator for a friend deep in the Amazon (not the online book place). A Savonius turbine is a vertical shafted rotor as in a 55 gallon drum cut in half and the two pieces welded together to make an "S" shaped rotor.
    The wind flutter device in the movie - Good luck finding a material that can hold up long term to the flutter movement! Also for a given wind speed there is only so much power in every sq foot of area. That device has very little wind exposure and will at best make very little power. I know, very little power in some remote locations is very nice to have.
    If I get anywhere with the Savonius rotor I will keep you posted.
    WNY, Buffalo Area
    873
    Talk about taking a problem and solving it in a very basic manner!
    I wonder if instead of scaling this up, what about creating an aray of smaller ones? Basically like how solar cells are put in to panels. Hmmmm........
    www.tinyurl.com/thewoodshoppe
    Jiutepec Morelos, Mexico
    230
    Three parameters influence the energy can obtained from the wind:
    wind´s velocity (it has a cubic factor), swept area and mass density of the air.
    Villa Park, CA
    1,407
    It's not clear how well this would scale up, but 40 milliwatts for household use is pretty small - in fact, it's tiny. As he shows, you can power a LED, or a clock, and maybe even a radio, but when you get beyond that you have to start thinking of some way to store the energy so that you can release it in larger amounts. You could put a bunch of these on a house, but you'd need 25 of these to get a single watt. So to light a 60 watt light bulb you'd need 1,500 of these generators.
    Alternately, the household could convert to LED lighting but that adds cost to the system solution. Even with LEDs you'd need a bunch of these things to provide any significant lighting (one LED doesn't provide that much light).
    And even then, you'd probably need to gather the energy during the day and store it in batteries so that you could use it at night - and when there's no wind. The cost of the batteries, and the maintenance of the battery system might make it a difficult solution for third world countries.
    Mike
    Ancora imparo
    230
    The bigger wind power generator, the bigger
    the blades. A technical problem with this increment
    is their transportation.
    Another way for energy storage
    http://en.wikipedia.org/wiki/Flywheel_energy_storage
  1. Wind Powered Saw Mill
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 05-19-2016, 11:17 PM
  2. Aeolian Wind harp
    By Chuck Ellis in forum Off Topic Discussion
    Last Post: 09-02-2014, 02:09 AM
  3. Wind is whistling!
    Last Post: 02-22-2013, 04:05 AM
  4. Wind Bottle Holder
    By Karl Laustrup in forum Off Topic Discussion
    Last Post: 05-27-2012, 12:51 PM
  5. Wind chime plans
    By Al killian in forum Designs, Plans and Sketches
    Last Post: 08-14-2007, 07:45 PM
