Results 1 to 10 of 15
Thread: Pool Cues?
    Red Deer, Alberta, Canada
    618
    Question Pool Cues?
    A friend wants to know if I could turn a pool cue for him. My lathe is a midi lathe and not long enough to turn a cue in one piece. Does anyone know where I could get the hardware (I have no idea what it even looks like) to build a two- or three-piece pool cue. Also, anyone know of a tutorial on the web that could explain how to go about this?
    For a newbie turner like me this seems like a big challenge and I'm just dumb enough to like a challenge.
    EDIT: Just realized, there must be some provision for the weight of the cue, as well. Any thoughts on that?
    I think that Vaughn is your go to guy on this question, give him a chance to wake up and I"m sure he'll be a great help!
    Jay
    11,834
    Google it. A lot if information will turn up. Custom pool cue makers use highly specialized lathes and inlay equipment. You are right in thinking that coupling is the way to go.
    6-8 hrs of labor will get you a stick that`ll be inferior to a 39.95 special from the billiards supply.....been there-done that
    Gord, the other guys pretty much summed up what I've learned about making pool cues. If you're friend's a somewhat serious player, then I suspect he wouldn't be satisfied with one made on a midi lathe. The cue-making lathes I've seen are more like a metal lathe, with a precisely controlled tool bit carriage (or whatever it's called) to ensure a perfect taper.
    This site has quite a bit of info and supplies, and as Frank mentioned, Google will show a whole lot of others:
    http://www.cuesmith.com/
    Perhaps you could make your friend a pool cue case instead?
    618
    Thanks for the input guys!
    With all this information I think I'd rather just go buy him a cue.
    Building on Vaughn's idea, maybe you could turn him a case that looks like a giant pool cue. He could get some good laughs out of walking into a pool hall with a cue that's two inches thick.
    Orem, Utah
    936
    I was kicking around on the FineWoodworking site tonight, trying to get more money's worth out of my one-year online "subscription". I don't know if non-subscribers can get to this item, but it's a PDF of a 4-page article called "Turning a Pool Cue":
    Thanks Kerry. An interesting read, and I guess it does show it's doable on a standard wood lathe. (And of course that prompted a search for pool cue turning blanks, which then ate up another hour or so skipping across the Intertube.)
    11,834
    Quote Originally Posted by Kerry Burton View Post
    Couldn't get in. I won't say turning a pool cue on a standard lathe is impossible. But, it nearly is. That long, slim form is just way too 'flexy' for decent turning. I have tried canes and walking sticks and ran into the same problem, even with a center steady-rest. That's why most kits for cues and canes involve couplings for making in sections. My canes have ended up with one end clamped in my big Neander post vice and being taken down with a drawknife.
  1. Build a pool table
    By John Case in forum General Woodworking Q&A
    Last Post: 06-17-2013, 02:59 PM
  2. Pool partition
    By Darren Wright in forum Carpentry and Construction
    Last Post: 06-07-2011, 04:28 AM
  3. Just put 150 lbs of Ice in the pool
    Last Post: 07-22-2010, 12:14 PM
  4. Solar Pool Heater
    Last Post: 06-07-2010, 11:31 PM
  5. Tag Team Pool Cue Case
    By Vaughn McMillan in forum Flatwork Project Showcase
    Last Post: 12-24-2006, 12:09 PM
