Results 1 to 10 of 13
Thread: Buckeye burl and Blackwood
    Sep 2007
    Brookhaven, Ms
    64
    Buckeye burl HF with Blackwood pedestal and finial. 4 1/2" diameter by 11 1/2" tall, lacquer finish.
    Travis..........that is stunningly elegant! I don't know how you manage to keep raising the bar but you do! Very, very well done Sir!
    Mason Michigan
    455
    This once again shows why you are the best!
    Did you spray or rub on your finish?
    Fort Worth, Texas
    241
    Stunning is the right word for this. I love the base and the finial is icing an a gorgeous cake!
    I may be lost but I'm making good time!
    Three Seasons Woodturnings
    Oct 2007
    Harvey, Michigan
    687
    Amazing work as always Travis! Love the detail work on the finial!
    30,017
    You're ratcheting the standard up another several notches, Travis. That's an absolutely gorgeous piece.
    Sep 2007
    Brookhaven, Ms
    64
    Pete, that's Deft lacquer from a spray can. Several coats then wet sanded after it cured.
    Goodland, Kansas
    4,834
    Holy cow Travis that is beautiful. Just stunning.
    Bernie W.
    That is stunning to say the least!
    You say you wet sand after it cures...?
    How long do you wait until it cures, in general?
    If you are wet sanding, do you worry about getting any water in the inside of the form?
    Thanks for taking the time to share, inspiring
    Sep 2007
    Brookhaven, Ms
    64
    Stu, 2-3 days in general. I just dip the sandpaper in a bowl of water and shake off the excess, just enough to keep the paper wet. I hold the piece on a towel in my lap, so there's not much worry of water getting in places it shouldn't.
  1. Stabilized buckeye burl
    By John Daugherty in forum Classified Ads
    Last Post: 04-28-2013, 06:59 PM
  2. buckeye burl
    Last Post: 04-28-2013, 06:57 PM
  3. Buckeye Burl Natural Edge
    By Mark Cothren in forum Lathe Project Showcase
    Last Post: 12-03-2009, 05:01 PM
  4. Buckeye & Blackwood
    Last Post: 04-20-2009, 01:55 AM
  5. Ramone burl and Blackwood
    By Travis Stinson in forum Lathe Project Showcase
    Last Post: 09-03-2007, 02:41 AM
