Results 1 to 5 of 5
Thread: Design Beltsander and progress
    Sep 2007
    613
    Designed my new lathe beltsander, and I'm already busy with making parts.
    The beltsander is lathe powered.
    Use two separate belts, the same as used on small hand beltsanders.
    These belts are very cheap, one belt cost nearly 2 euro.
    Use one beltsander for flatten the smaller half segmented rings, and both for the larger.
    This is the second piece of machinery, to use together with my new mitre saw for making more perfect segmented rings, anyway I hope so
    Cheers.
    Attached Thumbnails Attached Thumbnails 100_1407 - nylon linear bearings.jpg   100_1409 - spindle headstock.jpg   100_1410 - coupling half mounted on spindle headstock.jpg   100_1412 - coupling completed.jpg   100_1413 coupling with roller.jpg
    100_1414 - coupling with roller.jpg   100_1415 - coupling with roller.jpg   samenstelling sander.jpg
    Orem, Utah
    935
    That's some pretty impressive design and construction work, Ad!
    I assume you'll be posting pictures of the completed sander?
    Sep 2007
    613
    Quote Originally Posted by Kerry Burton View Post
    Hi Kerry, takes me another couple of weeks to complete this beltsander.
    But in the maintime I show you the progress, still a lot of work to do before I can show you the completed sander.
    But I love it to make my own stuff, to be honest more than woodturning.
    Thanks for your attention.
    30,014
    I'm looking forward to watching this one get built, Ad. Please do show us pictures as you progress.
    Sep 2007
    613
    progress on the beltsander
    80% of all the parts of the beltsander are finished. Next week I put the whole thing together.
    Here some pictures of what I did sofar.
    Attached Thumbnails Attached Thumbnails 100_1418 - rollers and coupling.jpg   100_1419 - bearing blocks.jpg   100_1420 - sanding belts and pads.jpg
  1. More progress!
    By Carol Reed in forum New Systems and Builds
    Last Post: 06-01-2016, 01:07 AM
  2. Progress!
    Last Post: 05-28-2016, 03:19 PM
  3. Guitar Design(s) (in progress)
    By Josh Duke in forum Designs, Plans and Sketches
    Last Post: 02-14-2011, 04:52 AM
  4. Completed beltsander
    By Ad de Crom in forum Jigs and Fixtures
    Last Post: 11-10-2007, 08:49 PM
  5. Progress
    By Tyler Howell in forum Shop Tours
    Last Post: 03-19-2007, 10:26 PM
