Results 1 to 6 of 6
Thread: pm 66 problem
    Milton, Fl., 30 miles northeast of Pensacola
    8
    Unhappy pm 66 problem
    blade height adjustment frozen. where do i look. i have already determined there is no piece of wood or visible trash causing the problem. it appears the worm gears have moved out of alignment in some way. any ideas? saw is approximately 5 years old with light use.
    4,992
    randy, it`s very likely the adjustment locking device that`s frozen, try backing out the center thumbwheel untill it can be removed, then jar the adjustment wheel firmly by hand....if no luck you might have to remove the top?...i`ve never heard of the worm gear loosing alignment? but anything is possible....tod
    8
    tod
    the wheel has always been hard to turn. but last night the wheel started to slip on the shaft. i removed the wheel and could see that it had been partially slipping for a while. i also noticed small burrs on the area of the worm drive that i could see. it appears something has come loose allowing the gears to get out of alignment. it was probably not in good alignment when delivered. i thought the stiffness would work out over time; however it hasn't and now it appears to have come to a head where i can't ignore it.
    4,992
    randy, sorry about not being able to offer sound advice without looking at the machine .......i`m guessin` only.......tod
    8
    tod
    i understand. i will have to take the top off. just dread it since i have a excaliber slider attached, which i don't know if i will have to remove.
    Odessa, Tx
    1,813
    Quote Originally Posted by Randy Paulk View Post
    tod
    Randy, do you have the maintenance manual for your 66? Unless your saw is different from mine, there is a procedure in the maint manual for aligning the lifting mechanism, (with drawings), and it does not mention removing the top. It does however mention that if there has to be an adjustment (side to side I think), that the table top may have to be realigned to provide clearance for the blade.
    Hope this helps.
  1. I've got a problem
    By Guy Bratt in forum General Woodworking Q&A
    Last Post: 01-20-2015, 07:27 AM
  2. I have this PROBLEM.....
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 02-11-2009, 04:41 AM
  3. Old Cat Problem
    By Bill Grumbine in forum Off Topic Discussion
    Last Post: 09-20-2007, 03:28 AM
  4. SU6 problem
    By Jeff Horton in forum Designs, Plans and Sketches
    Last Post: 02-15-2007, 11:11 PM
  5. Problem ID'ed How do I fix it?
    By Jeff Horton in forum General Woodturning Q&A
    Last Post: 01-21-2007, 12:32 AM
