Results 1 to 7 of 7
Thread: Ornament, a bit longer......
    15,809
    .......time wise and length......
    Hard Maple with a Walnut Finial.
    A bit different shape on this one, still needs some work, OK a lot of work, not quite where I want it, but...... Christmas is coming!!
    I did a few things different on this one, I got some paint and painted on the lines (Boy you can tell when your shape is NOT round, the paint lines DO NOT want to go on evenly ) and I also stuck some sticker things on this one, not very visible in the first pics, so I took some close ups........
ID:	14114 Click image for larger version.
    I also put a few coats of rattle can lacquer on this one, to make it more durable.
    Comments, suggestions and critiques welcome!
    566
    Not bad, not bad at all. Is it a two piece ornament. I am sure it must be as it would be nearly impossible to hollow it otherwise. How small is it? It looks pretty small.
    I like the addition of stars. I am not too sure about the stripes but to each his own. Your finish would be very reflective on a Christmas tree. You have come a long way on your finials. It looks nice and slender. Good work, I would like to do as well.
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    Oct 2007
    Harvey, Michigan
    687
    Nice work Stuart! Nothing in the photo to gauge size with - so, what is approx length/width?
    Goodland, Kansas
    4,834
    Not to bad Stu. Is it a two piece and did you hollow from the finial end? Well done.
    Bernie W.
    Nice job, Stu. At the rate I'm going, it'll be sometime in February before I finally try turning some ornaments.
    Charlotte, NC
    1,487
    You're getting pretty good at those!
    15,809
    Sorry guys, it was almost 5 AM when I put that up, so I did not get all the info needed up there
    Nearly 8" long, so the finial is not as thin as I'd like, but getting there!
    The ornament is the typical two piece job, cut in half, hollow out each side, glue back together.
    I'm not sure with the stars and paint either, maybe one or the other, but I'm still trying to figure this stuff out.
    BTW, I'm finding I really do NOT like Walnut for the Finial, too porous when it gets thin.
  1. I'm No Longer a Virgin
    Last Post: 02-08-2016, 03:54 AM
  2. I no longer have any excuses...for anything!
    By Bill Satko in forum General Woodworking Q&A
    Last Post: 04-23-2012, 07:39 PM
  3. no longer American
    Last Post: 12-03-2010, 07:03 PM
  4. No Longer waiting on Brown..
    By Don Baer in forum New Tools
    Last Post: 05-05-2010, 11:11 AM
