Results 1 to 10 of 18
Thread: How to make a curved front dawer
    Catalunya
    4,632
    Hi there.
    I have decided to start a couple of projects at the same time while I'm waiting for the different finishes of my chair to dry, and one of them is a chest of drawers, as the front of the drawers will be curved (see drawing) I wonder if is there any trick or special technique to make them.
    If I had a big lathe I could have glued the boards on a square wooden box and turn four of them at a time, but I haven't any and the only way I can imagine is by using section templates and hand planning.
    Making some chamfers on the jointer and finishing them is a possibility but I'm not so sure in how to make them in a repetitive way and all equal.
    Any help will be great ly appreciated.
    Thanks in advance
    Best regards,
    Toni
    toni, there`s a couple of ways to make single plane curves....cutting them out of solid stock as you mention is one. if you go that route then make a female template that you can slide up-n-down the length to check continuity.
    a better use of wood that will allow grain matching is to resaw thin plys and glue them back together using a form.
    The Ocean State
    170
    Check this out...A little diferent...but the basic idea
    http://books.google.com/books?id=egE...YcBr4#PPA71,M1
    Catalunya
    4,632
    Hi Tod.
    Thanks for your hint. If I used your suggestion of laminating thin plys that would give a concave curved interior of the front of the drawer as well. Wouldn't it?
    Then, how would you treat the end sides of it?
    Best regards,
    Toni
    Hi Tod.
    dovetails on a curve..
    Catalunya
    4,632
    Yeah! That can either be fun or "funstrating" Would you place them parallel or radially following the curve?
    Last edited by Toni Ciuraneta; 11-05-2007 at 02:06 PM. Reason: Gave a second thought
    Best regards,
    Toni
    ya` lost me toni? the drawer sides would pretty much have to be cut at a larger radius than the inside of the face in order to have the tails follow the curve. here`s a hillbilly sketch-up
    Waterford, MI
    773
    If you've got a stationary belt sander long enough to do the drawer width, you could do a homebrew version (fixed radius) of something like the fingerboard radius jig that Grizzly sells to sweep it through an arc.
    http://www.grizzly.com/products/G0577
    Catalunya
    4,632
    Excuse me Tod, I apologise I had a lapsus, what I tried to mean was that being the end of the side rail a curve, the dovetails could be radial from the center point of the front curve. Those would be almost parallel (sides) dovetails, but dovetails after all wouldn't they? and it is my suposition that they would be easier to do and their tips would be less fragile than the others (left side) due to the grain orientation.
    I left the construction lines to clarify my point.
    BTW a "hillbilly sketch" is the same as a quick or rough sketch? Thanks for it and your help
    Best regards,
    Toni
    Catalunya
    4,632
    Glenn.
    Thanks for the info it will help me a lot.
    Dough
    thanks, but I do not have a stationary belt sander I'm afraid.
    Best regards,
    Toni
  1. Dovetails on a curved drawer front
    By Robert Horky in forum General Woodworking Q&A
    Last Post: 04-03-2016, 04:54 PM
  2. New Front Vise for Dad
    Last Post: 12-03-2014, 02:06 AM
  3. And the front fell off
    By Drew Watson in forum Off Topic Discussion
    Last Post: 06-25-2010, 01:51 PM
  4. Make a Hook Tool - Easy to Make
    Last Post: 10-03-2009, 07:44 PM
  5. Trying to make some saws...(did make a couple backs)
    By Alan DuBoff in forum Neander Tool Questions and Show & Tell
    Last Post: 07-20-2007, 06:41 PM
