Results 1 to 10 of 11
Thread: Home made tools. Lots o' pix
    Hey all. Since there seemed to be some interest at RobustFest '07 in the hook tools and skew I made, I thought I'd share techniques and pictures.
    First I started the forge fire. It's really smoky at first, but once the coal really gets crankin' the smoke disappears and you get a nice wispy - read:hot! - flame.
    Next I have to mark the O1 tool steel rod where I want to cut it. I marked it every 9" with a cold chisel, using a holdfast in my pritchel hole for a third hand.
    I used a cutoff hardie in my hardie hole to drive the hot steel down and cut it off. Demo piece here since I didn't have a helper to take pictures.
    Next I flattened the end and tapered it to make for less grinding at the belt grinder. Next time I don't think I'm going to bother with this step.
    I went to the belt grinder with 40 grit and shaped the edge close to the finished taper. Another "for next time": finish the inside of the hook to a much higher grit so I don't have to do so much work with the hone later. Note that I don't grind the finished edge at this point - if the steel gets too thin there's a good chance I'll burn it in the forge. Yes, steel burns and it's not a pretty sight when you're trying to make an edged tool.
    Then it was time to turn the hook. I got it red hot and turned it around a piece of 1/4" rod. Next time I'll try a larger hook diameter.
    More to come...
    -Joe
    Mooreland, Indiana
    171
    Joe,
    You keep that up and you'll run me out of business.
    Randy,
    Maker of Fine Lathe Tools & Accessories.
    Quote Originally Posted by Randy Privett View Post
    HA! Not much chance of that at my current production rate
    The story continues. I moved on to the skew next, which I'm making from 1 1/4" x 3/8" thick O1 steel.
    First I needed to make my tongs fit the steel. Toss them in the fire, grab the steel and smash them in the vise. I also squeezed the handles to make them grip at a comfortable distance apart.
    Now I need to define the shoulders of my tang. I used a spring fuller for this.
    Then it was a matter of beating the daylights out of the tang to stretch and thin it out. I had to keep an eye on the sides, too, as the steel spreads in all directions, not just the one I want. So every few heats I have to flatten the sides back down to their original 3/8" thickness.
    Then it's off to the grinder to make it pretty. I rounded the tang, the entire bottom of the tool and broke the corners on top. I also ground the start of the edge shape.
    Then it was time to harden. To do this I brought the tools up to the temperature that they were no longer magnetic and held them there for a minute or so. Then they were dunked into preheated automatic transmission fluid. They were then hard enough that a file wouldn't bite.
    Here's my day's work, ready to be tempered.
    Tempering is just baking them in an oven at whatever temperature you desire in order to pull some of the brittleness from the steel. I tempered at 400F for 2 hours. Tool steel that has been hardened but not tempered will shatter like glass if you strike or drop it. I've seen it myself and it's cool as all heck, but not something I want in a turning tool.
    This is why you don't hit things that aren't nails with your framing hammer; it's too hard. You don't right?
    Anyway, here are my tools right out of the oven. Notice the golden patina on them - this is the "tempering color", which is another indicator you can use if you temper with a flame instead of an oven.
    To be continued...
    -Joe
    Sacramento, CA
    1,367
    I sure wish my wife would let me bake tools for xmas this year.
    Jason Beam
    Sacramento, CA
    Final installment!
    Here are the finished hook tools:
    And the skew, with my 3/4" and 1/2" crown skews for size comparison:
    Want to see that curly maple handle up close? Me too:
    And how about a close up of the hook? Since taking this picture I ground the bottom of the hook to make for a shorter cutting edge, making it a bit easier to turn a tight radius at the bottom of a hole.
    Here's the first hook tool in action!
    I don't have any pix of the skew in action, but we put it to the test at Bill's this weekend, and I think it performed admirably. It's got a great feel to it. Even Bill tried it out and gave it his stamp of approval
    -Joe
    Kutztown PA
    252
    Joe,
    Don't worry Randy. He might have the hook, but he has a way to go before he gets the line and sinker too!
    I didn't get to try them (except the skew), but they looked very well made.
    Bill
    Bill Grumbine
    www.wonderfulwood.com
    11,833
    When you say "homemade" you mean it. Be proud. Those are fine.
    Speaking of which, did you see how nicely my Monster-Wood-Toolrest works?
    -Joe
    Charlotte, NC
    1,487
    Thanks for sharing! I love seeing that kind of stuff being done!
    Mooreland, Indiana
    171
    Quote Originally Posted by Joe Fisher View Post
    -Joe
    Oh really, I didn't notice.
    Good job...
    Randy,
  1. Lots of Tools 4 Sale - Rockler, Craftsman
    By Kevin Gregoire in forum Old Ads
    Last Post: 12-21-2009, 06:22 AM
  2. Home made captive ring tools
    By Joe Fisher in forum Turning Tool Questions and Show & Tell
    Last Post: 10-12-2008, 08:59 AM
  3. My Home Made Hollow Rig
    By Wayne Bower in forum Turning Tool Questions and Show & Tell
    Last Post: 04-23-2008, 11:12 AM
  4. Home made tools
    By Terry Quiram in forum Lathe Project Showcase
    Last Post: 04-19-2008, 01:01 AM
  5. My First Home Made Tool
    By Pete Jordan in forum Turning Tool Questions and Show & Tell
    Last Post: 03-28-2008, 12:09 AM
