Results 1 to 10 of 10
Thread: Completed beltsander
    Sep 2007
    613
    Finished my work on the lathe powered beltsander for my own use.
    Runs very smooth with 400 rpm.
    It's not mothers most beauty, but it works like I wanted.
    It's mounted on the headspindle of the lathe lathe with a coupling and a clamping device, so easy to mount and easy to take off.
    Anyway for me, a lot of fun building such a thing.
    Have fun.
    Attached Thumbnails Attached Thumbnails 100_1428 completed  beltsander.jpg   100_1429 completed beltsander.jpg
    Jul 2007
    DSM, IA
    5,719
    Ad, well done. The best part is that you had fun making it.
    My Website
    Orem, Utah
    936
    Very Cool, Ad!
    I looked back through your original [Design Beltsander and progress] thread, but I can't figure out how you adjust the belt tension or alignment. Either there's something I'm not seeing, or your tolerances are very tight indeed!
    Sep 2007
    613
    Thanks Jeff, for sure I had a lot of fun.
    Sep 2007
    613
    Quote Originally Posted by Kerry Burton View Post
    Very Cool, Ad!
    Hoi Kerry, every roller has his own slot brech on each side, needed to bring inline the roller connected with the coupling, and also to set the other rollers parallel
    It's just the matter to set the rollers parallel by tension by hand. I controled this with a caliper. Not much tension is needed with using this kind of sanding belts. Thanks for your attention.
    Ad
    BTW. I give it a try to figure out an oval turning device, not sure if I succeed,
    but I see a possibility, so if you are interested, I keep you informed
    on your personal email address, if this is okay by you.
    Anyway something to brake my neck on.
    Orem, Utah
    936
    Thanks for the reply ...
    ... and YES, I'm interested!
    Great job on a very inventive idea, Ad.
    Albuquerque, New Mexico
    1,099
    Necessity is the mother of invention.
    Ad, very clever. Where’d you get the idea from or was it your own?
    friend...if you have one."
    one."
    Sep 2007
    613
    Quote Originally Posted by Bruce Page View Post
    Thanks Bruce, it was my own idea, but as a mechanical engineer I know how to build things. I have a small workshop, so this solution was the best for me.
    1,289
    You never cease to amaze me Ad, Great job!
    DT
  1. Another completed project
    By Alan Bienlein in forum Flatwork Project Showcase
    Last Post: 04-13-2011, 05:41 PM
  2. completed Rocker
    By ray klosek in forum Flatwork Project Showcase
    Last Post: 11-17-2009, 03:15 PM
  3. Workbench Completed
    By Rob Luter in forum Flatwork Project Showcase
    Last Post: 05-30-2008, 09:08 PM
  4. Design Beltsander and progress
    By Ad de Crom in forum Jigs and Fixtures
    Last Post: 11-01-2007, 02:53 PM
  5. crib completed
    By Chris Mire in forum Flatwork Project Showcase
    Last Post: 04-30-2007, 12:40 PM
