Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Turning Pics Setup
    Tyler, Texas
    336
    Turning Pics Setup
    I'm sure this has been asked before either here or on that other forum but I'd like to know how to achieve pics of my turnings like the ones I see posted here.
    Travis Stinson, Mark Cothren, Jim Ketron and probably others post these great looking pics with a light foreground changing to a bluish background.
    What sort of photo box setup do y'all use? Is the seamless paper blue? How much light is necessary and where positioned?
    I know that's a lot of questions but I'd really like to improve my picture taking. I have a Nikon D50 digital camera so that shouldn't be the problem. Any advice is certainly appreciated.
    Cody
    Orem, Utah
    935
    This "inquiring mind" would like to know more, too! I've worked out that a low-cost solution can be set up as shown below ... but there must be more to the setup you "experts" use! Especially lighting-wise...
    30,017
    Cody, the backdrop you see is a gradient background.
    Here are a bunch to look at. "Thunder Gray" is the dark one you see a lot of; I have "Studio Gray" myself.
    The photo cube/tent I use came from eBay. I've bought one good one and one cheapie one there, so they do vary from vendor to vendor. (I don't recall who I bought my good one from.) For lights, I use three 5,000K fluorescent bulbs in the aluminum clamp-on fixtures available at the hardware store. Here's my setup. (You should recognize the camera):
Name:	Photo Tent - 01 800.jpg
ID:	14584 Click image for larger version.
Name:	Photo Tent - 02 800.jpg
ID:	14585 Click image for larger version.
Name:	Photo Tent - 06 800.jpg
    Orem, Utah
    935
    Ah-ha! I suspected a gradient background of some kind, but I wasn't sure they even made such things.
    Vaughn, what's the wattage on the bulbs you use for this particular setup? It looks like I have everything but the "right" bulbs....
    Sep 2007
    Brookhaven, Ms
    64
    Yup, Vaughn gave you the hot setup. I have the Thunder Gray background and use 1 or 2 lights, along with a white cardboard. I believe my bulbs are 40 watt.
    30,017
    Quote Originally Posted by Kerry Burton View Post
    I think mine are 40 watt, like Travis'. More important than the wattage is the color temp. I've hear that 5,000K was the right number to look for. (Perhaps someone who knows more can chime in with more info.)
    The professional gradient backdrops that I linked to are pretty pricey. I know other guys have simply made a gradient background with a graphics program like Photoshop, saved the result as a JPG file, then taken the file to Kinko's and got it printed on large stock. For a few bucks, you can still get a pretty good backdrop. I'd suggest sticking with neutral colors, though. As tempting as a hot pink to blue gradient might seem, shades of gray tend to work with a bigger variety of pieces.
    Orem, Utah
    935
    Thanks guys!
    Yep, I caught the 5000 K color temperature reference, but I wondered just how many watts at that "temperature" it took to light:
    * a turned piece
    * through the surfaces of a light tent
    * in an otherwise (mostly?) darkened space
    40 watts per bulb sounds like surprisingly few ... any idea what your average aperture and shutter speed are with that amount of light? If not, no big deal; just curious.
    I appreciate the photos of your setups!
    PS - Travis, I only see one light (in use) in your "wide" shot. Is the one in the second shot kinda hanging from the ceiling? Are there other lights that don't show up in the first photo?
    30,017
    Kerry, I run my camera on aperture priority, and crank the f-stop down to F/25 (to get the maximum depth of field). My shutter speed ranges from about .75 to 2.0 seconds...whatever the camera thinks is right. The three lights are sufficient at that slow of speeds. And a tripod is a given. (I also use the self-timer set at 2 seconds, so there's no tripod wiggle.) I shoot the pics in an otherwise darkened room.
    Sep 2007
    Brookhaven, Ms
    64
    Yup, it's out of the shot in the 1st pic. It's mounted up and to the left of my tent.
    Well, I've been using three VERY bright halogen worklight lamps, and my pics still are too dark
    Maybe the darkened room would help or I can try some of them compact bulbs....
  1. Problem turning "Willow" bowl blank UPDATED with PICS
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 08-23-2014, 08:06 AM
  2. the new pic setup
    By larry merlau in forum Site Questions and Test Posts
    Last Post: 02-15-2014, 09:34 PM
  3. Best Setup
    By Dennis Allen in forum New Tools
    Last Post: 06-13-2013, 01:46 AM
  4. Tormek Setup
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 08-26-2008, 03:54 AM
  5. Oval turning device-work in progress pics.
    By Ad de Crom in forum Jigs and Fixtures
    Last Post: 04-10-2008, 06:31 PM
