Stuart Ablett
- Tokyo Japan
I just made a couple of tools up, one, for drilling the stick pens that I'm making (Snowman Pens).........
I was able to get some L-O-N-G 3mm drill bits, so I put a handle on the bit, makes it a LOT nicer to use.
The second item is a "Brand" I made up, I just use a stylized "SA" my initials to sign my work, but until now, I've been using an old screwdriver, and just heating it up to make the four burns, now I made up this brand to do the same thing.....
Works well, and is MUCH easier to get a good looking brand each time.
You can see the "S A" on the block just behind the branding iron.
