Results 1 to 10 of 12
Thread: Upside Down Alder Hollow Form
    More from the plain alder stash. I decided to try a bit more bottom-heavy form again. If you turn it upside down, the form is more conventional. Some will like it...some won't. I'm still undecided on the form, but the foot does seem to float it off the table in a neat way. It's about 8 1/2" wide by 4 1/2" tall, and it's fairly plain, but I like the wood, and the Tung Oil Blend/lacquer finish came out pretty good IMO. I did a little playing around on the rim with the woodburner. Still lots of experimenting to do with it.
    Lots o' pics, just because I have 'em.
Name:	HF041 - 02 800.jpg
ID:	14795 Click image for larger version.
Name:	HF041 - 03 800.jpg
ID:	14796 Click image for larger version.
Name:	HF041 - 04 800.jpg
ID:	14797 Click image for larger version.
Name:	HF041 - 05 800.jpg
ID:	14798 Click image for larger version.
Name:	HF041 - 06 800.jpg
ID:	14799 Click image for larger version.
Name:	HF041 - 07 800.jpg
ID:	14800 Click image for larger version.
Name:	HF041 - 08 800.jpg
    Let me know what you think...good, bad, or indifferent.
    Vaughn, I like it. To me the form is eye catching especially with the raised lip. The edge burning works for me as well. I would like to know the size of the opening and the wall thickness. Good Job!
    Chris, the opening is 1 1/2", and the walls are about 3/16" thick, and a bit thicker towards the bottom, ending at probably about 3/8". I typically don't really measure the thickness, aside from using the laser as a gauge as I'm going. And even then, I usually don't get too brave about making the bottom thin. I'd rather have a nice form with a slightly-weighted bottom than a nicely-formed donut with a ventilated bottom.
    BTW, welcome aboard.
    Sep 2007
    613
    Vaughn, I like the form and the burned rim, it seems to me you have an affair with this type of holllow forms, saw so many of those hollow forms on your website. Never thought about a collar??
    BTW. beautiful wood for this type of hollow form. Great job !!
    Ad
    Real nice, Vaughn. Refreshing to see some new shapes in hollow forms, and I love the rim treatment.
    -Joe
    Oct 2007
    Harvey, Michigan
    687
    Vaughn - this works for me! Nice flowing curve, beautiful finish and even the burned rim fits in with the color scheme!
    Was the lacquer a spray-on or wipe-on? Have thought about using lacquer for a while now but there's no way I could spray while in the shop (basement) during this time of year.
    Chris - glad to see you found your way over to this site! When you get the time - make sure you get over to the Welcome forum and let everyone know you are here!
    Steve
    North Ogden, Utah
    348
    I think you nailed it with the elevated foot. It really does float and keeps the bottom heavy form form looking so heavy. The burning at the opening goes great with it too.
    Mooreland, Indiana
    171
    I love this form. Keep moving forward with what your doing. I like it.
    Randy,
    Maker of Fine Lathe Tools & Accessories.
    Fort Worth, Texas
    241
    Yeah, yeah... just keep raising that bar, Vaughn.
    I like this. It has a neat SW feel to it.
    I may be lost but I'm making good time!
    Three Seasons Woodturnings
    Thanks for the nice words, guys.
    Quote Originally Posted by Steve Schlumpf View Post
    ...Was the lacquer a spray-on or wipe-on? Have thought about using lacquer for a while now but there's no way I could spray while in the shop (basement) during this time of year...
    I'm using Deft spray. I can open up my garage and ventilate it pretty well when I'm using it. This piece has about 6 or 7 light coats, then I wet sanded with 600 grit and buffed on the 3-wheel system.
  1. Spalted Alder Hollow Form WIP
    Last Post: 05-22-2008, 03:29 AM
  2. How long does it take to hollow out a small hollow form?
    By Mike Hirsch in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 07:47 PM
  3. 'Nother Alder Hollow Form
    Last Post: 10-24-2007, 07:41 PM
  4. Spalted Alder Hollow Form
    Last Post: 06-28-2007, 01:48 PM
  5. A hollow form that's not a hollow form!
    By Bernie Parmenter in forum Lathe Project Showcase
    Last Post: 05-09-2007, 05:28 PM
