Results 1 to 10 of 22
Thread: ca glue source
    Oliver Springs, TN
    1,726
    ca glue source
    Where do you get your ca glue. I will be making a few pens for my daughter's teachers as Christmas gifts and need some ca glue.
    Another question. I have been gluing the tubes into the blanks (both wood and acrylic) with 5 min. epoxy. As of late I have been having a problem of pushing the tube out of the blank when I use my end mill to flush-up the blank. I have waited a couple hours before trimming and still had the problem.
    11,825
    All I use is the 5 min. epoxy. I usually wait a few hours for set-up. I'm guessing you are not mixing completely. It does set firmly. I put my glue on sheets of cheap printer paper and mix with a toothpick and apply to the pens with the toothpick. Works for me.
    Some like CA, I don't.
    Oliver Springs, TN
    1,726
    thanks Frank
    Just in case.....
    Make sure that you are sanding the tubes prior to glueing. If you are not doing this, it only takes a second to wrap 120 grit around the tube and make it scratched and shiny. It will give the glue something to hold on to and makes a big difference in my opinion. Good luck!
    Oliver Springs, TN
    1,726
    Thanks Robert, I do sand the blanks before gluing. Would a dull end mill have anything to do with the problem?
    Hi John.
    Berea Hardwoods specializes in pens and accessories. They sell CA glue in 1 and 2 Oz. plastic bottles.
    11,825
    Quote Originally Posted by John Daugherty View Post
    Do you mean 'tubes' you sand, not blanks? Unlikely the end mill affects bond between the tube and blank.
    San Antonio, Texas
    765
    John, I get my CA and epoxy here.
    Oliver Springs, TN
    1,726
    My mistake, I should have said tubes!
    Oliver Springs, TN
    1,726
    Thanks Billy
  2. source for cyclones
    By Rich Soby in forum New Tools
    Last Post: 07-16-2011, 11:04 AM
  3. Ci1 Cutter Source
    Last Post: 06-01-2009, 12:56 PM
  4. SuperNova2 jaw source
    By Chip Charnley in forum Turning Tool Questions and Show & Tell
    Last Post: 10-19-2007, 05:42 PM
  5. looking for source
    Last Post: 06-19-2007, 11:30 AM
