Results 1 to 5 of 5
Thread: Feather...rollers
    Nov 2007
    Poland
    267
    Feather...rollers
    Good day
    All the idea is actually a "feather board" but instead of the "feathers", I'm using rollers (or wheels) that are spring loaded by a metal bar and keeps the workpiece pressed to the fence before entering the blade.
    Because of the distance between the wheels, the workpiece is held firmly pressed to the fence from the beginning of the fence till almost the blade.
    To make it even more effective, I tilted the wheels down and the result is that the workpiece is also pushed and held down to the table.
    As you will see, it's very easy and fast to install/adjust/remove (I replaced the wing nuts with knobs) and I almost don't make any rip cut without those wheels.
    When the workpiece is passing the table edge, I just grab the push block or lately, long push stick (I can use any long scrap because I need only to push forward) so, my body and hand are far away from the "war zone".
    A word about push sticks...I've seen on the Internet that people are pushing the workpiece at a point close to the fence...I think that it's much better to push at a point that is closer to the blade because we create another vector that tends to push the workpiece toward the fence and not toward the blade back teeth...
    Regards
    niki
    Niki, I think (?) I've seen this one before, but that don't matter, as it is a great fix for the feather board problem.
    Way to go!
    Charlotte, NC
    1,487
    Great jig Niki!
    11,832
    Simple and effective. I like simple.
    Nov 2007
    Poland
    267
    Thank you so much
    Stu
    I'm posting from Aussie through Italy, UK, CA, USA and down to Brazil so, it's most probable that you have seen it already...
    Frank
    With the resources that I have in Poland, it must be simple...well, I also don't know how to make complicated jigs...
    Regards
    niki
  1. Planer feed rollers
    By Tony Baideme in forum Old Iron
    Last Post: 09-04-2013, 01:30 AM
  2. Euro guides or Rollers
    By Al killian in forum New Tools
    Last Post: 11-25-2008, 02:31 AM
  3. Hold-down rollers
    Last Post: 12-01-2007, 12:23 AM
  4. Someone Tar and Feather Me
    By Travis Johnson in forum Carpentry and Construction
    Last Post: 11-13-2007, 09:37 PM
  5. Industrial rollers
    By Kevin Brady in forum Hot Deals
    Last Post: 01-03-2007, 09:44 PM
