Results 1 to 6 of 6
Thread: Hollow Form #6
    Oct 2007
    Harvey, Michigan
    687
    Hollow Form #6
    Experimenting with various shapes. This one is out of spalted birch and is 8” x 4 ½”. Sanded to 400, finish is Watco ‘Natural’ oil, buffed.
Name:	HF 6 View 1.jpg
ID:	14892 Click image for larger version.
Name:	HF 6 View 2.jpg
ID:	14893 Click image for larger version.
Name:	HF 6 View 3.jpg
ID:	14894 Click image for larger version.
Name:	HF 6 View 4.jpg
    Any and all comments or suggestions are appreciated! Especially looking for any more input with regards to photography!
    Thanks for looking!
    Steve
    Sep 2007
    613
    Steve, your experiment went out well, I like it, beautiful wood.
    And there is nothing wrong with the pictures, the pictures are very clear to me. Keep em going, great job.
    30,014
    Man, that's a pretty one, Steve. Beautiful wood. Number 6? I'd say you seem to have the knack.
    The photos look great. The only suggestion I can think of would be to try lightening the pics a bit more -- especially the last two. I like to bump up the "Lighten Shadows" slider a little bit in Photoshop Elements, followed by a similar bump to the "Midtone Contrast" slider.
    Here's a screen shot from the "Quick Fix" view in PS Elements. I only moved the Lighten Shadows" slider (which started all the way to the left) and the "Midtone Contrast" slider (which started in the middle position):
Name:	PS Tweaking 800.jpg
    And here's the result of that tweaking, as well as rotating the piece 1 degree to the right:
Name:	Steve Schlumpf HF 6 View 3T.jpg
    Does this help?
    Oct 2007
    Harvey, Michigan
    687
    Vaughn - everything helps at this stage! The 'copy' of photoshop that I have is version 5 and all the adjusts are very time consuming and make huge differences. I have been playing with them some - just need a little more time to figure out what works and what doesn't. Like I said - all information helps - so thanks!
    Biggest difference for me with the photos was taking your suggestion about the slider controlling the compression. Went from a 10 (max) down to a 7 and found very little change in photo appearance and a huge difference in viewing size! Been looking for that for over a year now! A big thanks for that one!
    Steve
    30,014
    Glad it was some help, Steve. That "Quality" slider eluded me for quite a while too (originally in Irfanview, but also in Photoshop). As you saw, it makes very little if any visible difference on-screen, but it will make a difference on prints, so I always save "fat" and "thin" versions of my good shots. All the shows I've been entering require photos for the jury process, so it's handy having a few good prints.
    I can also relate to the differences between the Photoshop versions. I use Photoshop LE V4.0 at the office and a current version of Photoshop Elements at home. The "Elements" edition is a lot easier to use. I've also got Photoshop 7 available at the office, but I haven't gotten around to installing it. My photoshopping at work is limited to screen shots and other simple graphics, so I've not really needed the extra complexity of version 7.
    Fort Worth, Texas
    241
    I may be lost but I'm making good time!
    Three Seasons Woodturnings
  1. first hollow form
    By Clark O'Neill in forum Lathe Project Showcase
    Last Post: 04-14-2008, 02:08 AM
  2. How long does it take to hollow out a small hollow form?
    By Mike Hirsch in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 07:47 PM
  3. Box? Not exactly. Hollow Form? Well, no....
    By Kerry Burton in forum Lathe Project Showcase
    Last Post: 05-12-2007, 10:28 AM
  4. The Next Hollow Form!!
    Last Post: 05-01-2007, 02:34 AM
  5. Hollow Form
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 04-30-2007, 10:34 PM
