Results 1 to 6 of 6
Thread: Hold-down rollers
    Nov 2007
    Poland
    267
    Hold-down rollers
    Good day
    I made as an aid to hold the Outfeed side pressed to the fence but later I made it with two wheels, one before and one after the blade.
    Again, the wheel is inclined toward the fence and when the workpiece is passing, the wheel presses it to the fence.
    I set the wheels height to about 5/32"~1/4" below the board height by changing the spacers.
    Regards
    niki
    1,289
    That's an ingenious tool you have there Niki, look out Board Buddies!
    DT
    Nov 2007
    Poland
    267
    Thank you Don
    At my age (62) I love the things "under control" or even better under "remote control"...I mean, with my hands and body far from the guarded blade...
    When I'm using the "feather rollers" or the "hold-down rollers" or both (in case of long thick boards), nowadays, I'm using a loooong push stick that keeps me out of the "fire zone" and I feel very safe and relaxed that "somebody" is holding the workpiece for me...I just have to push...
    Regards
    niki
ID:	14907 Click image for larger version.
    The 2 roller system would work very well with the sliding rip fence hold down in the latest issue of Shopnotes [Vol 16 Issue 96]. I desigened that and sent it to them. It would let the push block follow the rollers thru the cut so full control is maintained till the cut is finished.
    I currently use it with a set of board buddies but I have altered the sliding mechanism design to reduce the height above the fence.
    Keith
    Kansas
    417
    Quote Originally Posted by Keith Krueger View Post
    Keith
    Is this it here?
    http://www.shopnotes.com/issues/096/...ing-hold-down/
    Rise above the rest
    Yes that is the sliding hold down I sent to Shopnotes.
    For people that use the Gripper this hold down works very well especially on narrow rips.
    Keith
  1. Planer feed rollers
    By Tony Baideme in forum Old Iron
    Last Post: 09-04-2013, 01:30 AM
  2. Hold it!
    Last Post: 06-16-2009, 04:29 PM
  3. Euro guides or Rollers
    By Al killian in forum New Tools
    Last Post: 11-25-2008, 02:31 AM
  4. Feather...rollers
    Last Post: 11-29-2007, 06:22 AM
  5. Industrial rollers
    By Kevin Brady in forum Hot Deals
    Last Post: 01-03-2007, 09:44 PM
