G0513X and Timberwolf
glenn bradley
SoCal
Not news to a lot of us but wanted to post for those who'll ask. Got 3 Timberwolf blades for the BS today. They work great. The Griz blade was nice but the Timberwolf blades rock. They are also helping to fill out the second pegboard panel on the new wall and will be joined by other BS stuff.
You will enjoy the T'wolf blades, while they last. Like you, when I changed from other brands to T'wolf I found the cutting to be much faster and smoother, really great. Downside, they wore out very quickly. When I contact Suffolk Machinery about this they told me to expect about 200 lineal feet of cutting from a T'wolf blade. Strangely, thickness doesn't seem to be a factor. One inch or one foot thick same lineal cutting expectation. I dunno why :huh: they didn't explain. Now, only 200 feet can be just about one afternoons worth of cutting. That's not much. For some folks it would mean buying a new blade daily. Let us know your experience. BTW, if I ever upgrade my G0555, it will probably be to one like yours. I like that resaw fence.
I did notice that they say to run a blade no more than 2 - 3 hours at a time and are obviously addressing mill work type use. My previous Timberwolf blades cut as great after many hours of use and they were sold with the old BS.
Now that I have a larger and more usable BS I'm sure I will use it more frequently and possibly for longer periods at a time. I'll post a few months down the road and see how they do. I do consider most any plain steel cutter as a throw-away item (kinda like brake shoes on a car) but hope to get my money's worth of cuts out of them ;-)
My experience was with a 3/4"X3tpi blade on my 14" bandsaw, cutting no more than six inches thickness.
Frank,
I've had exactly the opposite experience with TW blades. I use 3/8'-3tpi AS (alternate set for green wood) blades with green wood and get over a years use from them. I would say I've cut at least a hundred green wood bowl blanks (and four or five nails by accident in some old scrap lumber) over the year and the blade is still plenty sharp. I also cut dry and pressure treated wood with these blades and I can't kill them.
I had a couple of 3/8" Morse blades that didn't last long at all for cutting a mix of wet and dry woods. Yes, I know these blades weren't designed for green cutting.
It may be that I'm cutting green and you're cutting dry woods that makes the difference. I don't know or want to guess...I'm just adding my two cents.
FYI-Roller bearing guides aren't good with green wood. The basic guide blocks work better for green wood. The rollers tend to compress the wet dust and cake up the blade sides.
Dick
At the time I was cutting a lot of Eastern red cedar and Osage orange. Both, according to Suffolk Machinery, contain a lot of silica that dulls blades quickly. Nevertheless, the 200 foot thing is the figure Suffolk gave me as a general guide. That is their advice. For a while now I have been using several 'I dunno' brands of blades given to me by a friend. They cut fine and seem to be lasting. I dunno why :dunno: but the seem to be good.
I've had really good service from TW blades, on both my 14" and 16" saws.
So far, though, the best blade live has been from a 1/2" bi-metal blade I got from Louis Uturra. It's been on the Laguna for about siz months now, and still cuts like new.
The fastest wearing blade I've had so far has been the Highland Wood Slicer. Great blade when new, but it wore very quickly - I'd guess I got about a hundred feet of cherry (6" ~ 10" wide) before it dulled noticeably. I quit using it soon after that - maybe at about 150 feet.
My experience with Timberwolf involves my bandsaw sawmill (one of those sawyer-gets-behind-and-pushes-the-carriage models). I won't go into the mill, since if I had it to do over I'd buy someone else's, but in casting about to find ways to improve its performance I noticed a Timberwolf ad (this was maybe 7 or 8 years ago). I gave them a call, asked a couple of questions, and man this guy talked to me for over an hour. He really seemed to know his stuff about bandsaws and blades. At the end of the conversation I ordered a half dozen blades (figured if nothing else it was reasonable tuition for a worthwhile learning session). While I was waiting for the blades to be delivered I did a couple of things to the mill that he had suggested, and put a nice cherry log that I had gotten at my brother's place on the log deck. When the blades arrived I installed one, canted the log, and made some boards. All I could say to myself was Wow...that blade did a great job. And so did the other 5. And so have all the other blades that I've since bought from Timberwolf. I don't keep a lot of usage data since I think of the mill as one of my woodworking machines, and 3 or 4 sawlogs keeps me in cherry for a long time, but from a performance standpoint those blades made me stop looking. Someone mentioned green wood, and I definitely believe it's a factor in blade life. Because of the moisture content the fibers are softer, and the moisture actually acts as a lubricant. Wood dried to 10% MC or less is much harder on tools. Of course by that time it has shown its true character with regard to how it's going to behave as part of a piece (warp, twist, etc), which you need to know, and has shrunk to at least close to its resting size, so cutting everything green isn't an option. I think an appropriate phrase might be "live with it". All high speed steel is probably not created equal, but even the best (which it is my belief TW tries to acquire) is going to have more trouble staying sharp in dry wood than in green. And there's more to it than the lubrication factor of green wood...tpi (which determines gullet size) is a factor, because that determines how well sawdust is cleared from the cut. If it isn't cleared efficiently, heat builds up. Tooth set factors into that as well. The blades I've been using on my 16" bandsaw (Grizzly G1073) are from BC Saw and Tool. This is the result of happenstance rather than an exhaustive usage trial...awhile back FWW had an article about maximizing performance from your bandsaw (don't they all, and oh so often), and the author of that article mentioned that this company was now his only source of blades. So I phoned in an order for 5...I'm happy with them, and still have a couple of new ones hanging on the wall. Are they better than Timberwolf?...I doubt it, but they're probably as good. My take on it is that some companies bother to send you cutting tools that are sharp enough (or nearly so) to use out of the box (Lie-Nielsen and Lee Valley to name a couple). But even so, the best can still benefit from a honing before use...problem is, sharpening a bandsaw blade (particularly a sawmill blade) is no picnic (at my age I sometimes wonder if my warranty is going to expire before this job is finished). So the first-blush gee-whiz factor from bandsaw blade manufacturers who care is usually pretty high...and imo it's important, because nobody in his right mind spends half his life sharpening his bandsaw blades. If its performance out of the box is better than someone else's, it's a better deal...I seriously doubt that one guy's hss vs another guy's hss is the difference maker (carbon-tooth blades are another matter). How long will it stay sharp?...well, what species are you cutting, what is its moisture content, are you resawing or cutting stock that's 1" thick or less, have you matched tpi to the job at hand...to say that a bandsaw blade will only provide a maximum of two hour's use isn't saying enough...if you try to cut a 1/4" steel rod with it it will last about two microseconds.
Glenn, I'm seriously considering upgrading my bandsaw to the G0513X...do you have a thread about your original purchase?...I couldn't find one.
Glenn, I'm seriously considering upgrading my band saw to the G0513X...do you have a thread about your original purchase?...I couldn't find one.
You caught me Ed. I say in this post 'http://familywoodworking.org/forums/showthread.php?t=6032' that I will do a more thorough review once settled in with it. I have been negligent. I will endeavor to do that before the end of the upcoming weekend.
Bruce...
Thanks for the comment. Istavan doesn't ring a bell. If my Grandma was alive she'd know...she could cite the family tree from rootlets to topmost twig and tell you where everyone was ("in the ground" was an acceptable report).
Regards
Ed
Glenn...
Drove over to the Muncy showroom today to pick up a couple of machines. While I was there I spent some time checking out the G0513X2 bandsaw and the G0514X2, which were sitting there side by side. They're very similar, capacity and HP being the primary differences. Considering the size of my shop and the kind of bandsaw work I do, I've decided that the G0513X2 is the right one. I'm hoping that Mr. Balolia will see fit to put it in the summer sale flyer...if he does I'll be in Muncy the following morning to pick it up...if not, might be a week or two later. Between now and then I'd appreciate knowing if for some reason you fall out of like with it. Thanks.
Glenn...
I love this machine more every time I use it. I'll watch for any annoyances till summer and let you know. They do not include a light but even that doesn't bother me as most manufacturer's put them places we users cannot understand. A mag-base lamp from HF for about $10 works great and I can stick it wherever I like.
Glenn...
The lathe didn't work out for me...had to return it. When I drove over to Muncy to do that, I came home with the G0513X2. Mr. Balolia is still my main man for woodworking machinery. It isn't installed yet, have to move some heavy stuff around first. I plan to order 3 Timber Wolf blades for it, and 3 blades from BC Saw & Tool. Someday when the dust settles I'll post a comparison. So far just looking at it I love it, but as yet no spinnee.
