Frank Fusco
- Mountain Home, Arkansas
OK, not first shavings but first attempt at a project. This hunk of very hard dunno wood will (might) end up a hollow form. Got an opportunity to experience the EVS. Found the control is very sensitive, a tiny turn can increase RPMs a lot. Love that soft start, had to hit the emergency red turn-off button once. Good feature. The picture is actually with the wood turning but my flash froze the motion better than I expected. The lathe runs very smoothly and quietly. Even with fresh, out of balance, hunk on there was no detectable motion of the lathe, solid. I wanted to test the power by really putting a gouge to the wood. But my new Steb center proved a huge disappointment. I think it thinks it is really a Forstner bit. Wouldn't hold worth diddly. I would tighten the tailstock and the Steb would just dig in deeper. So trying hard just stopped the wood. Lathe kept going. One surprise, I watched the digital read-out and found that the RPMs actually increased as I put the tool to the wood. With a load, the speed would increase about 10 to 20 RPM. That is, until the Steb/Forstner started digging in. Finally got my tenon turned. Will put chuck on sometime tomorrow and see wat hoppens. Forgot pics. Will add in another post.
