Results 1 to 4 of 4
Thread: Small Gravity Feed Spray Gun Question.........
    .........I got this little gun in a set of air tools a while back, OK, a LONG while back, I've never used it, but I figured it would be good for spraying the small amounts of dye on some turnings
    This is the gun, nothing special, but it should work (I hope).
    I think I have the controls figured out, and by that I mean I know what they do, or control, but I'm not sure yet how to set them up. I've sprayed a few cups of water through the gun to see how it functions, to figure out the controls.
    Does it look like I have them pegged?
    I know that every gun can be different, but I figure this is a knock off of an existing design, so it should be similar to others?
    Middle side seems to control the size of the fan, or spray pattern, the one at the back of the gun seems to control the material flow from the paint cup, and the one near the butt of the handle seems to control the air pressure.
    I found that wiping on the dyes did not work well, they would end up unevenly covering the wood, and a brush was not much better. On the containers the dyes come in it even states that they have found that spraying on the dyes seems to get the best results, thus, I'm going to try this gun.
    Tokiwadai, Japan
    2,882
    Stu,
    I have a Craftsman gun that looks very similar. Your control descriptions are the same as on mine. I also haven't used mine, but got it a long time ago with my compressor.
    The Heart of Dixie
    4,268
    That is the same gun I have. Sold under the Ingersol Rand name. Your on the money. Spraying some carboard to start with. Took me a while to get all the setting to play nice but I am happy with it. Not a great gun but it will work.
    Custom built boats and Kits
    Thanks guys, and as I already owned it, I figured what the heck, I'll give it a try.
  1. Fuji 2203G Semi-PRO 2 - Gravity HVLP Spray System
    By Joe Acquisto in forum Finishing School
    Last Post: 11-18-2015, 06:49 PM
  2. PSH-! gravity feed cup source?
    Last Post: 08-05-2014, 12:32 AM
  3. Spray Finish Setup - Question
    Last Post: 08-01-2011, 07:16 AM
  4. spray gun question???
    Last Post: 09-26-2008, 12:02 AM
  5. Porter Cable PSH1 Gravity Feed Spray Gun
    By Matt Guyrd in forum Hot Deals
    Last Post: 03-01-2007, 06:09 AM
