Results 1 to 10 of 10
Thread: Electrical Problem
    Pennsylvania
    361
    Electrical Problem
    Last night during some heavy winds & rain, we lost power to our outside electrical receptacles. Don't know exactly what happened. The rest of the house is fine. I thought maybe the circuit breaker tripped but when I checked the panel, it hadn't. I tried flipping that circuit off and on a few times but I can't seem to get power back to those outlets. It is a GFCI circuit but I can't seem to find the reset button on any of the outdoor receptacles.
    Wouldn't be a big deal except for, you know, the Christmas lights. Anyone have any advice short of calling an electrician?
    Contoocook, NH
    129
    The outlets may be ganged off of another GFI recepticle, try checking the gfi outlets in the kitchen or bathroom.
    Richard "Butch" Leshner
    Or you may have a GFI circuit breaker on your distribution panel.
    Jay
    Woodstock, GA
    178
    Also check in your garage or basement, they are required there also and can be wire with the outside outlets. One other place in my house is the outlet to supply the spa tube in the bathroom is below the counter and is GFI.
    4,992
    bob, i think you`ve got the right answer allready......there`s another one tripped inline....tod
    Pennsylvania
    361
    Thanks guys but my frustration level is at an all-time high right now. I've gone through the entire house about ten times trying to find this GFCI reset. It's not on any of the outdoor boxes & I checked all the indoor ones (kitchen, baths, basement). I left a message for one of my neighbors to see if he knows where it would be since he has the same model house as ours.
    Just what I wanted to be doing today.
    Woodstock, GA
    178
    Rob,
    The GFI outlets will sometimes go bad will they will not reset, all GFI outlets set pop off when you push to test button if they do not check with a meter to find if there is power to the GFI. if there is then the unit is bad.
    Pennsylvania
    361
    Found it. Now I really feel like an idiot. There's an outlet right next to the electrical panel that contains the reset button for that circuit. I couldn't see it because I've had the panel door open & it was covering it up. All is well.
    4,992
    well rob........you`ll never forget exactly where that first outlet is ....on to better things.....tod
    Woodstock, GA
    178
    Quote Originally Posted by Rob Bodenschatz View Post
    Glad to hear it was something simple
  1. An RV Electrical Question
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 04-29-2014, 08:33 PM
  2. Electrical Problem
    By Dan Mooney in forum Carpentry and Construction
    Last Post: 08-01-2011, 12:58 AM
  3. electrical scare
    Last Post: 12-10-2008, 02:07 PM
  4. electrical fan ?
    Last Post: 09-04-2008, 04:28 PM
  5. Electrical Done(?)
    By glenn bradley in forum Carpentry and Construction
    Last Post: 10-14-2007, 09:31 PM
