Results 1 to 7 of 7
Thread: Question from a rookie finisher...
    Fredericksburg, VA
    161
    I have a small project that I have been finishing over the last few days. After applying stain, I applied four coats of General's Seal-A-Cell varnish, sanding with 320 grit in between coats. Here is my question...now that I have applied the fourth and final coat of General's, is that it? Am I to now rub this finish out? I want this item to gleam, and show of the curly maple grain. What am I to do.....if anything?
    Thanks!!
    - Keith
    "Listen, here's the thing. If you can't spot the sucker in the first half hour at the table, then you ARE the sucker. "
    5,321
    Quote Originally Posted by Keith Starosta View Post
    Thanks!!
    - Keith
    I'd put a couple coats of Arm-R-Seal on it now. It's made to go over the Seal-a-Cell. It's a harder finish that polishes well after it's cured.
    Fredericksburg, VA
    161
    Thanks, Jim.
    Would the Arm-R-Seal get sanded with 320 between coats as well? Also, what would be the ideal method of polishing?
    - Keith
    5,321
    Thanks, Jim.
    - Keith
    Yes, it would. Final polish would be to sand to 1000, or more, then use a polishing compound, then wax. I use a Meguiar's auto polishing compound, and prefer Reniassance Wax (it's expensive, but it works well.) I think LV has a micro-crystalline wax that's cheaper, but I haven't tried it yet.
    Fredericksburg, VA
    161
    Thanks, Jim!!
    - Keith
    An article on rubbibg out a finish: http://www.taunton.com/finewoodworki.../011119046.pdf
    Fredericksburg, VA
    161
    Unfortunately, I'm not a member of the Fine Woodworking site, so I couldn't download the PDF file. Thanks anyway, Glenn.
    - Keith
  1. Rookie question on dovetailing
    By Rich Soby in forum General Woodworking Q&A
    Last Post: 08-27-2015, 03:17 PM
  2. I want to shoot a lazy no count finisher!
    Last Post: 07-27-2011, 03:31 AM
  3. Mortising hinges rookie question
    By Bob Gibson in forum General Woodworking Q&A
    Last Post: 08-13-2010, 01:17 PM
  4. SketchUp Rookie
    By matt fonner in forum Designs, Plans and Sketches
    Last Post: 05-03-2010, 10:39 PM
