Results 1 to 6 of 6
Thread: What to thin poly with???????
    Floydada, Tx
    1,941
    Question What to thin poly with???????
    I just bought a spray system and while does a good job a spraying lacquer and stains, it doesnt do good at spraying thick oil based poly. So what works best for thinning it? On hand I have, mineral spirts, DA, Lacquer thinner and Aceatone. Or do I need to buy something different?
    From Fine Woodworking (for wipe on):
    Use mineral spirits to thin oil-based polyurethane
    by 20% to 30%
    I would assume a bit more for spraying but MS seems to be the recommended thinner. They also, oddly enough, voted Minwax wipe-on poly as the easiest to use with the best outcome. I say 'oddly enough' because I hear so many folks complain about Minwax(?).
    566
    I agree with Glenn's response but I have a question myself.
    When I thin polyurethane with mineral spirits and store it in an air tight container in just a few days it will gel. Is that because I have incorporated too much air into the mix while stirring in the MS or some other reason?
    I still use a poly/oil/MS home brew on occasion and learned that I cannot make much more than I plan to use as it will almost certainly gel in a few days.
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    Floydada, Tx
    1,941
    OK, I will give it a go. Like Mike I also have noticed that that when I rinse my brushes that had poly on them in ms it turns to a white colored gel.
    read the can.......most manufacturers give thinning or clean-up instructions.
    often the "thinner" is listed as a "cleaner" because we all know that thinning finishes causes cancer in california rats and pregnant penguins.
    Floydada, Tx
    1,941
    Tod, it says to clean with either paint thinner or minerail spirits. I thinned it 1 part ms to 2 parts poly. It laid nice and smooth and dried in enough to recoat in 2 hours.
  1. Yes...it's thin enough!
    Last Post: 06-30-2012, 02:33 AM
  2. Thin Kerf Blade
    By Charles Hans in forum New Tools
    Last Post: 09-04-2011, 12:21 PM
  3. Thin Panel Question
    By Sal Cangialosi in forum General Woodworking Q&A
    Last Post: 06-19-2010, 08:25 PM
  4. Thin NE Yellow Eucalyptus
    Last Post: 12-29-2009, 02:55 PM
  5. Thin Maple Bowl
    Last Post: 10-10-2009, 08:45 PM
